Question about Kenmore 3.2 cu. ft. Top Load Washer
Leveling a washer tub how to do so
I need to know how to level a washer tub
  • katie king Sep 30, 2007
    the outside of the machine is level... it is the tub on the inside that goes over to the back left (as you look)of the inside machine.. so i have to stand and keep moving the tub over so it will not rub
  • 164 Answers
First get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Posted on Sep 28, 2007
  • Geoff Siegel
    Geoff Siegel Sep 30, 2007
    If you had made it clear as to what was wrong with your washer you would have recieved the information you desired. instead you asked a general question and recieved an appropriate answer
Washer overflows I think around the tub and spills out only in the front area. This is the second time it has done it. I don't know what is causing it...thankfully, most of the water runs under the wall...
If your washer is overfilling, check the water inlet valve and water level switch. A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.Also a defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 25, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Does not stop filling with water
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Feb 01, 2010 | Hotpoint VBXR1090D Top Load Washer
My Kenmore Heavy Duty 70 washer is out of balance and bangs like crazy during the spin cycle. What can I do to repair it myself
If this is a Whirlpool manufactured top loader (such as your Kenmore), it could simply be off level. The rear feet on these washer have an auto-leveling mechanism that you can easily reset yourself. Just follow these steps:
1. With the wash tub empty, open the washer lid and grasp the rim of the tub opening (do not grab the tub).
2. Now place one of your feet at the base of the washer along the front of the washer to keep it from moving.
3. Now pull the washer towards you so the rear feet lift off the floor. You should hear a clicking sound as the rear feet auto-level.
4. Carefully set the washer back down (do not slam it) and the rear of the washer should now be level.
Using a level, check the washer front to back and side to side to make sure it is level in all directions.
If you need to adjust the washer washer front feet, carefully lift the front of the washer and turn the feet to either adjust them up or down. The slightest difference can cause excessive vibration on the final spin. Check by placing your hands at opposite corners on top of the washer (diagonally - one on the rear, one on the front) and try rocking the washer to see if it moves. If the washer wobbles, you need to readjust.
If you still have problems after checking the level of the washer, please post back and let me know. The problem could also be related to balance spring issues. I hope this helps you.
Jan 12, 2010 | Washing Machines
During the rinse cycle, my washing machines shakes violently from side to side (It just started doing this a couple weeks ago). Is it off track, and is this issue self-repairable?
If this is a Kenmore top loader, it could simply be off level. The rear feet on these washer have an auto-leveling mechanism that you can easily reset yourself. Just follow these steps:
I suspect that auto-leveling the rear feet will take care of the problem, since this just recently started happening. This needs to checked from time to time.
If you still have problems after checking the level of the washer, please post back and let me know. The problem could also be related to a balance spring issues. I hope this helps you.
Jan 05, 2010 | Kenmore 24032\24036 Top Load Washer
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Washer machine over flow at start up
Hi There
I have this for to read and hope this gets you in the right direction. Let me know how it goes.
Thank you for writing to fix ya.
Dec 29, 2009 | GE WBSR3140DW Top Load Washer
Washer is all over the place!
If you've recently had the washer apart for maintenance, you probably have managed to unlevel the washer. The rear feet of Whirlpool manufactured top loaders are auto-leveling. You can usually tell if the washer if off level if the back appears to be sitting lower than the front. You can reset the level by following these very simple steps:
1. Make sure the wash tub is empty.
2. Open the washer lid and grab the rim of the wash tub opening (do not grab the tub).
3. Place one foot against the bottom front center of the washer.
4. Pull the washer towards you so that the back feet come off the floor. You should hear a clicking noise as the rear feet automatically level.
5. Lower the washer back in place and use a level to ensure the washer is level front to back and side to side.
This is a common issue when moving or doing maintenance on the washer. Many consumers do not know about the auto-leveling feature of these washers.
If you find that the washer is still unlevel after resettting the back feet, adjust the front feet by using a wrench to adjust the feet.
I would attempt these procedures first before assuming a bent shaft. I have never seen that occur. Its not to say that it can't, but its probably not common.
If you have any questions, or if you still need assistance, please let me know. I hope this helps you.
NOTE: Kenmore washers are manufactured by Whirlpool.
Oct 01, 2009 | Kenmore 23822 Top Load Washer
Washer water over flows during start up
Hi Darcy,
I suspect that the "air dome" on the outer tub is blocked by what we affectionately refer to as "Bio-Gookus".
First an explanation... the water level switch that was replaced has a tube connected to it. This tube runs down into the machine and connects to an "air dome". The air dome is connected to the outer tub (It has 2 tubs, btw. The one you put your clothes in is surrounded by an outer tub to keep the water in).
OK... as the water level rises, so does it rise in the tube connected to the level switch. As the water level rises, so does the AIR PRESSURE inside the tube. This pressure exerts a force on the diaphragm of the level switch. When the water reaches the set level (specifically, when the air pressure in the tube exerts enough force on the diaphragm) the level switch trips and shuts off the water valve and turns on the agitator.
So much for the fundamentals... Knowing what you know now, you'd know that if anything were BLOCKING the water level in the tube to the level switch, then the level switch wouldn't know when to turn the water off, right? That would mean that something is interfering with the air tube to the level switch.
That's what I suspect, anyway.
Now for the fix... You'll need some "Torx" bits. They look like this.I think it's a T8 that you'll need, but don't hold me to that.
Put the washer in Spin and make sure all the water is evacuated, then shut it off. Now, {{{UNPLUG THE WASHER}}}
Use your Torx bit and remove the 4 screws on the very top of the control panel. Then rotate the panel towards you. On the left hand side you'll see the level switch (the one with the clear plastic tube on it). Remove the tube from the switch. (I know the next part is gonna sound goofy, but bear with me) Now blow as hard as you can through the tube. It should be difficult and you should hear air escaping from somewhere under the machine.
When you hear air escaping, you just fixed your machine! You overcame the resistance of the "Bio-Gookus" and sent it retreating into the dark places it belongs! Victory!!!
Now for the follow-up. You should go get yourself some of this, or something similar. Use a couple of bottles to start with to thouroughly clean the machine, then one every 6 months or so to keep the "resistance" at bay.
Simple, eh?
SG
Mar 25, 2009 | GE WBSR3140DW Top Load Washer
you dont level the tub, level the feet on the bottom of the machine
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
452 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
