Question about RTO Suburban Rv Water Heater Dsi Gas Valve Part 161109
Water heater doesnt heat when on eletric setting works on gas
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: the electronic ignition on a gas water heater will
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Posted on Jul 20, 2010
motor1258
  • 6674 Answers
SOURCE: the water heater is not heating on elec, and its
First of all, let's deal with electric side of water heater first. Make sure breaker in main panel is on, second, any switches on wall, that may even say, microwave / water heater on same switch, needs to be in correct position, or on. Also at back of water heater there is usually another switch on metal or plastic cover where you see hydro cable entering. May be on top, may be on side, but check and make sure it's in the on position as well. Sometimes,when switch on side I need to use a mirror and a flashlight to see it better as space is sometimes limited and doesn't allow for good view of switch , without the mirror. If all those are in proper position, there are a few more things to check, so get back to me after those are checked and I'll guide you through the rest if necessary. Before I get in to Propane operation part, please confirm model number of water heater and that it is DSI . (automatic, electronic ignition) Has it been working good up until now?
Posted on Nov 13, 2010
Bosch water heater
Most likely the thermocouple is bad. If its bad it will not allow the gas line to open.
Aug 20, 2014 | Water Heaters
Eletric water heater not heating up to 125
Include product brand, model and type for best possible answer.
Include if this is new installation, or installation that worked before and stopped working.
Oct 03, 2012 | Stiebel Eltron Stiebel TEMPRA24PLUS Eltron...
Heater wont start. I replaced the pressure witch, doesnt work, I by passed the pressure switch and put the red and blue wire together and it will run until it gets hot. I remove conected wire and...
What water heater do you have?
Is this a tankless or tank-type water heater?
If tank-type, what gas valve is on the heater?
What does the water heater manual say?
Add a comment with more information for possible help, or possible re-direct to correct expert.
Sep 22, 2011 | RELIANCE ELECTRIC WATER HEATER
I've lost my manual, and am unsure what the heat
You posted under water heater.
Open following link for adjusting water heater temperature on typical gas and electric water heaters:
State electric has ABC
White Rodgers gas thermostat has ABC
Honeywell gas valve has ABC
Each is shown on following link:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
60 degrees C is 140 degrees F.
You can get burned pretty quick at 140 F.
I suggest 125-130 F and see if that works
First aid for burns is to apply cool water immediately.
Jul 09, 2011 | Rheem Water Heaters
I have the rheem pronto in one of my rentals and the water is cold all the time. Help!!!
3 items possibly:# 1) has that gas company turned off the gas lately to do some work?,and then re-fired the water heater after the work was completed? if so,check the temperature setting on the unit,as most gas companies upon re-start of gas appliances on their line will just set them to LOW,so as not to have an insurance issue with a scalding problem(from someone setting it TOO HIGH) if set above LOW temperature./ # 2) it could be limed up in the bottom and not have the capacity anymore to heat the full capacity of the unit due to this issue & needs shutting down and draining and a fresh re-fill. / #3) if the unit won't fire after the pilot has been lit(held down to keep lit) and then turned to a heat setting from pilot,you can have a defective thermocouple temperature sensor in the flame not letting the gas valve open fully to heat the unit
Jan 25, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Every time we put on the central heating our water runs cold
What kind of water heater do you have?
In any case, it sound like a plumber should check out system.
Do you have indirect heater that gets heat from central heating boiler?
Most indirect/boiler combo heaters have control that is set to heat the water first.
If water is not getting heated, then the control needs repair.
Do you have gas water heater with gas central heating?
The central heater may be drawing so much gas from meter, that other gas appliances are unable to function. larger gas meter or gas line may be needed.
Or if furnace and water heater vent on same chimney, the backflow from central heat could be affecting burner on water heater especially if water heater has electronic sensor that stop combustion if air quality is bad. Venting problems can lead to CO poisoning, and are a serious matter.
Nov 18, 2010 | Water Heaters
My water heater isn't working correctly. The temperature is set to 140 and the water is still freezing cold. I called the number on my water heater, but i had trouble understanding the man due to his...
if its electric its your element thermostat,if its gas the thermostat is down by the gas valve they are why water isn't hot,they are shutting off supply of either gas or electric they are both easy to install
Oct 17, 2009 | Water Heaters
Water heater doesnt heat up
has the unit every been cleand you can check the it in the service door
Dec 01, 2008 | Water Heaters
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
RTO Suburban Rv Water Heater Dsi Gas Valve Part 161109 Logo
20 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
