Question about Fire Magic 3590A Refrigerator
Motor hot but no cooling - Fire Magic 3590A Refrigerator
My cadi 1988 is running ruff and quit running feels like over heating but no leaks, just smells
REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.MAKE SURE COOLANT NOT LOW.IF ALL IS GOOD CHECK FOR LEAKING WATER PUMP WEEP HOLE IF LEAKING REPLACE WATER PUMP.MAKE SURE COOLING FANS RUNNING.IF ENGINE RUNNING HOT WHILE SITTING LONG TRAFFIC LINE AND COOLANT NOT RUNNING.CHECK COOLANT FAN RELAYS AND FUSE.IF ALL IS GOOD HOT WIRE MAKE SURE COOLING FAN MOTOR GOOD IF COOLING FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD.IF FAN MOTOR OKAY AND FUSE RELAYS GOOD YOU HAVE FAULTY COOLING FAN WIRING.YOU COULD HAVE BAD ENGINE COOLANT SENSOR OR FAULT IN ECM CODE SCAN TO CHECK THEM BOTH.CHECK ENGINE OIL.LOOK LIKE MILK SHAKE YOU HAVE LEAKING HEAD GASKET.IF OIL LOOKS OKAY.YOUR ENGINE BLOCK, RADIATOR AND HEATER CORE NEED FLUSHING.
Sep 20, 2011 | 1988 Cadillac Sedan DeVille
94 oldsmobile cutlass supreme oevrhaeting only one fan comes on
CHECK THE OTHER COOLING FAN FUSE AND RELAY.IF BOTH GOOD HOT WIRE COOLING FAN TO SEE IF FAN RUNS IF NOT YOU HAVE A BAD FAN MOTOR NEED TO REPLACE FAN MOTOR.IF FAN RUNS WHEN YOU HOT WIRE IT.FAN MOTOR WIRE CONNECTORS HAS A SHORT.
Aug 27, 2011 | 1994 Oldsmobile Cutlass Supreme
Engine runs hot after a few minutes of running the car
That is very vague. Have you checked the radiator, and when it is hot does the electric cooling fan come on? Try running the A/C and see if the cooling fan comes on. Does it run hot on the highway or just in city traffic? I need some more details to try and narrow it down. There are many things it could be. Low coolant, stuck thermostat, air in the cooling system, bad fan motor, fan motor relay (also known as fan switch), or temp sensor.
Jul 17, 2011 | 2000 Oldsmobile Intrigue
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Fridge not cooling.
If it is an 2 motor unit, just order a charge to the refrigerator... but first check if both motors are running, when making cool.
If it´s the gas charge, the refrigerator must be hot, be careful!
if no one hot, than could have a motor or the protection defect!
Best Regards
Aug 25, 2009 | Refrigerators
Fan motor runs for awhile and then runs hot and shuts off
Bearings in the motor may need oiling. look for a tiny funnel hole on a tube on the ends to oil it. Remove power first.
If none it could be permanently sealed and need to replace the motor.
Let it cool before touching anything. again remove power first.
Jul 06, 2009 | Heating & Cooling
AC BLOWER MOTOR GETS HOT THEN TURN OFF.
I HAVE A 1998 CADILLAC DEVILLE,THE AC BLOWER MOTOR GETS HOT AND TURN OFF AND WONT TURN BACK ON UNTIL IT COOL OFF, WHAT IS THIS PROBLEM?
Jul 04, 2009 | 1999 Cadillac DeVille
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Fire Magic 3590A Refrigerator Logo
15 people viewed this question
Top Fire Magic Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Fire Magic Refrigerator Expert? Answer questions, earn points and help others
