Question about Sony FD Trinitron WEGA KV-32FS16 32" TV
Enlarged Picture The television is producing a picture that is enlarged such that it cuts off certain elements. This includes the on screen channel display. I noticed a crackling/popping sound a couple of days before I noticed the picture was enlarged. Any ideas if this is fixable. I have searched the on screen menus and can find no controls to shrink the picture down to the proper size.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Yes it is fixable. this problem is due to more supply is going to h/output stage. please check 1 power supply for more voltage then normal. 2 component failure or settind in horz. stage to be checked. 3 print crack in h/output stage you can not control from remote control.
Posted on Sep 29, 2007
Akai 13" TV/DVD Combo CTD-1390 White Lines going across the screen with enlarged images on screen.
Retrace lines. This fault is called so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to CRT screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2014 | Akai Televison & Video
The picture is enlarged on the screen. how do you return the picture to normal size.
Please provide more details. Are you talking about the entire desktop or a picture?
You can try this. Hold the control key down and use the mouse scroll wheel to increase or decrease the desktop size. This scales everything.
Oct 09, 2014 | Panasonic TC-P50U1 Plasma TV
Picture enlarged
PC or laptop? Sometimes I find on my PC if I just shut off the moniter and turn it on again, it reverts to normal. Something in the conection, I think.
Mar 18, 2013 | Microsoft Windows XP Professional
The screen image has enlarged on its own. I have try to fix it by going to the horizontal and vertical settings and and I tried to adjust them but nothing worked. I would appreciate any suggestions, thank...
The normal basic troubleshooting for a TV; 1) Raster 2) Picture 3) Sinchr 4) Sound)
Since you have a Raster +Picture you must Test the section 3)Synchr bad is included by differentiator and integrator
see the block diagram attached and proceed very well, with Troubleshooting.
God bless you
Jul 07, 2012 | Televison & Video
Turned on the tv yesterday and it is like someone enlarged the picture so it does not fit in our screen. weather, sports, etc. are cut off, can't see whole show. Is it something in the set up menu?? How...
Hi, perhaps there is a Zoom button on the remote, try that! if this doesn't fix it the come back with the Make & Model Number and see if there are any other solutions.
Hope this helps.
Midge.
Feb 10, 2011 | Vizio Televison & Video
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
My kids were playing with the buttons on the tv, and itseems like the picture is now "stretched" vertically - the tops of heads are cut off, and it seems like some of the picture is missing from the sides....
there should be a zoom, or strech, or even the letterbox option somewhere. What your describing is a enlarged picture that doesn't fir the screen, like if I select zoom on my remote.
Dec 10, 2009 | JVC AV-36D302 36" TV
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
I have a Toshiba 27WLT56B. A year ago it developed a problem: (1) I have to switch it on from the buttons on top of the TV. (2) Only after 10 minutes does it respond to the remote control (RC). (3)...
there it is a complicated problem your tv seem to have one big problem with the supply module inside him the power current was accidentaly increased and now your tv dont respond better and your picture is enlarged because had a big alimentation current and now you must to go in authorized service to fix that problem
Dec 11, 2008 | Televison & Video
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
See all Sony FD Trinitron WEGA KV-32FS16 32" TV Questions
Sony FD Trinitron WEGA KV-32FS16 32" TV Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
