Question about Watches
Link required for ladies guess watch 3604 - Watches
escapement
  • 2334 Answers
SOURCE: Help with removing links from a Calvin Klein ladies watch
There must be something wrong as ALL watch bands are held together by pins or screws. Did you try to unscrew them? These might be screws instead of pins. And if these are pins, they MUST come out because there is NO other way to shorten the band.
I would advise you to find the watchmaker, not the jeweller, and he/she will be able to sort things out.
P.S. Not all the bands has pointing arrows on them, so, no worries about that.
Do not forget to rate, please.
Posted on Jan 06, 2009
SOURCE: removing links to shorten watch
I just removed links from one of the white stag watches today. The answer is in the link below.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Friction pins are used to hold the links together. I used a jeweler's screwdriver and a small hammer to tap them out in the direction of the arrow. I put them back in the same way.
Posted on Apr 19, 2009
SOURCE: the link on my mens guess watch came out about the sixth link from the watch face
Call the customer service line and they will send you links.
1-800-248-3775
Posted on Aug 03, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
  • 13 Answers
SOURCE: the ladies disney citzen eco-drive requires a charge
It needs LIGHT ... Put it under a bright lamp or out in the sunlight. It is SOLAR powered/charged. You may use a fluorescent lamp or an incandescent lamp but it will take longer to charge to full. If you use a regular light bulb (incandescent) make sure to keep 20cm distance from the watch to prevent overheating.
When it gets low on charge it will switch to only moving the sweep or second hand every 2 seconds, then after a while it will stop all movements and may move the hands to 12:00 (power saving mode). Again, It will need to be put in bright light to recharge.
Posted on Nov 08, 2009
Guess watch glass
jewelery store would be a good place to look
Apr 27, 2015 | Guess Watches
Broken ceramic link
David only a professional can fix this or replace it.
Feb 25, 2014 | DKNY watch - NY8430 Ladies Ladies
Ladies calendar date chronograph watch with digital dial
you dont say what you wont but if you click the link below you can download the manual
http://www.timex.ca/en/manuals.aspx
Aug 29, 2012 | Timex Ladies Calendar Date Chronograph...
I am trying to remove 2 links from a ladies indiglo watchband
mcdevito75 here, To remove the links from any watch band requires a special tool called a Link Remover tool, available on ebay. You can remove the links without the tool but the time and work, just isn"t worthit, even with the tool if you don"t know anything about watches, your best bet would be to look for a small watch repair shop in your area , and have them remove the links, hold onto these links in case you need to ever replace them.
Aug 26, 2010 | Timex 2J611 Watch
Type of battery for ladies guess watch
I have a guess W15514G2.. and I want to change the day in the watch, In the first click I am able to adjust Date on one side and month on the other side, the next click makes me adjust the time. But what about the Day? How do i adjust that? Help me
Jul 13, 2009 | Guess G66355L Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
The ladies disney citzen eco-drive requires a charge
Follow this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Interactive settings are helpful as well.
Rate me, please.
Apr 06, 2009 | Citizen Eco-Drive JR3080-51L Wrist Watch
Removing links to shorten watch for a ladies Wallmart watch brand is white stag #Ws50880w
Dec 28, 2008 | Pulsar Ladies Watch
Watches Logo
22 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
