Question about Comfort Zone Heating & Cooling
Source green heater flashing E3 - Comfort Zone Heating & Cooling
CZ 2020C Flashing E3, how do I fix it?
If you place a small fan behind the heater where the controls are it should quit stopping on you. There is a small thermal sensor that is getting warm and shutting down your unit. Its a safety item.. but it also works when you need your heater the most. So place that fan and it will blow the heat into your room better also.
Feb 08, 2015 | Heating & Cooling
E3 flashing light wont heat
Check the filter. Some heaters will not work if the airflow is inadequate to prevent the elements from overheating. good luck.
Dec 13, 2012 | Comfort Zone Heating & Cooling
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Canon pixma mp 145 e3
e3 means paper jam ..look for any jammed paper inside ...then try to reset..
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 flashing wat does it mean
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
service mode. (Waiting for menu selection)
3 times for Orange EEPROM reset.
button pressing
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E3 flashes when turned on
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 with E3 Flashing.
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD overcurrent error - USB
button pressing
procedures below.
procedures below.
Thanks, Joe
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 error message
Dude,
E3 refers to Paper Jam :)
this may come in handy:
Service mode operation procedures -
button pressing
procedures below.
procedures below.
îäíàêî, äëÿ ôóíêöèé 4 è äàëåå åñòü ïðèìå÷àíèå : òîëüêî äëÿ àçèè.
à âîò â îïèñàíèè ôóíêöèè 3 åñòü : Reset except for the
followings:
- USB serial number
- Destination setting
- Waste ink counter ...
Turn it upside down and than check.....same error code or diff.
Any help, can buzz me nytime ...
Thnks.
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Heating & Cooling Logo
159 people viewed this question
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
