Question about HP 1740A Oscilloscope, 100 MHz
Delay sweep not work
Wipers not funtioning properly
had u doing oiling in joint of the wiper and see moter is running normal or not
Sep 27, 2011 | 2002 Pontiac Montana
I CAN'T GET THE FILTER PUMP LIGHT TO GO OFF - BEEN USING IT FOR A GOOD PART OF THE DAY - LOTS OF LEAVES AND BLOSSOMS IN POOL.
There is a 5 min. delay on this sytem once you turn on the heater or pool sweep. During this delay you cannot turn off filter pump. Hope this helps.
Mar 18, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
What do the numbers 1 - 6 represent on the wiper side of the steerind wheel of the 2000 ghia
the numbers relate to the time delay,in seconds, when the wipers sweep.....
Jan 07, 2011 | Ford Focus Cars & Trucks
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Wipers swipe in off position randomly
Known issue with circuit board mounted on wiper motor. Has glitch which causes phantom sweeps. suggest replacing circuit board.
Aug 17, 2009 | 1998 Mercury Villager
1995 Clio, wiper work but do not return to the home position
There is an IC or Capacitor.Resistor network across the relay that times a full sweep. It is defective
Replace the Wiper delay relay
Mar 26, 2009 | 1986 Renault Sport
Pulling the trouble codes using a volt meter.
Self-Test with Analog Voltmeter DTCs will be represented by pulsing or sweeping movements of the voltmeter's needle across the dial face of the voltmeter (Figure 9). A single-digit number of three will be reported by three needle pulses (sweeps). However, a DTC is represented by a two-digit or three-digit number, such as 2-3. As a result, the DTC of 2-3 will appear on the voltmeter as two needle pulses (sweeps). After a two-second pause, the needle will pulse (sweep) three times.
The Continuous Memory DTCs are separated from the Key On Engine Off DTCs by a six-second delay, a single half-second sweep, and another six-second delay.
Using an Analog Volt/Ohm Meter (VOM)
  1. Turn the ignition key off.
  1. Set the VOM on a DC voltage range to read from 0 to 15 volts.
  1. Connect the VOM from the battery positive post to the Self-Test Output pin of the large Data Link Connector (DLC) (Figure 3).
  1. Connect the timing light.
17fa78e.gif Using the Malfunction Indicator Lamp (MIL) No special equipment hookup is required. STI is jumpered to SIG RTN at Self-Test Input (STI) connector and the Data Link Connector (DLC).
Self-Test with Malfunction Indicator Lamp (MIL) During Self-Test, a DTC is reported by the Malfunction Indicator Lamp (MIL). It will flash the "CHECK ENGINE" or "SERVICE ENGINE SOON" light on the dash panel (Figure 10). A single-digit number of three will be reported by three flashes.
However, a DTC is represented by a two-digit or three-digit number, such as 2-3 or three digit. As a result, the Self-Test DTC of 2-3 will appear on the MIL as two flashes, then, after a two-second pause, the MIL will flash three times.
The Continuous Memory DTCs are separated from the Key On Engine Off DTCs by a six-second delay, a single half-second flash, and another six-second delay.
Feb 23, 2009 | 1994 Ford Thunderbird
Flash is delayed
You have switched the self-timer on!
Press the button to the right of the displays just under the AV button. You need to ensure the display does not show the self-timer icon, which looks a bit like a second hand sweeping around a clock (with a dot at the 12 position).
That should do it.
Cheers
John
Feb 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
2006 Suburban, rear windshield wiper not working, can hear motor/pump trying to work but no movement.
with wiper on try to wiggle the wiper arm with your hand. if motor is stuck this will sometimes jar it loose. you may need to do this for a minute as the wiper is a delay system. also if you can move the arm thru its sweep then it is just the wiper arm loose if this is it remove cover at base and tighten nut
Jan 23, 2009 | 1999 Chevrolet Suburban
Wipers run way too long when i use windshield washer
The wipers are supposed to sweep after washer fluid for a while,but if that just started recently then the wiper control module which is part of the delayed wiper
Dec 18, 2008 | 2001 Jeep Grand Cherokee
HP 1740A Oscilloscope, 100 MHz Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
