Question about Toys
Evenflo Exersaucer Manual
How to change battery in model #25805249
SOURCE: evenflo exersaucer
I just bought replacement springs on evenflo's website for 45 cents each. Now I just have to figure out how to get them in.
Posted on Aug 17, 2008
SOURCE: I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Posted on Apr 19, 2009
SOURCE: need to put seat back on old evenflo exersaucer-no instructions
there should be small plastic clips on the material for the seat and then you just clip them to the plastic..... it sounds much easier then it is
Posted on Jun 06, 2009
MazzyA
SOURCE: how to remove the seat cover on exersaucer
Hi, all the way around it are plastic bits sticking out and the seat cover is clipped onto the plastic bits, just lift them off one by one, all the way around. then when your done clip them back in again. hope this helps.
Posted on Jun 16, 2009
SOURCE: Evenflo exersaucer with animals and a jeep which
It's a little tricky and you'll end up ruining a couple of hte stickers. This is what you'll need to do -
1. Pry the latches loose under the top that hold the jeep in place
2. Unscrew the 4 screws that hold the jeep to the base
3. 2 of the wheels have screws - use a small screwdriver to remove these
4. The window stickers on the same side as the wheel screws cover 2 more screw holes - you'll need to feel for these and poke holes through the stickers to get to the screws.
5. Once you remove all these 4 screws, the jeep should come apart in 2 halves. Dont exert too much pressure while separating them.
6.The inner assembly (purple with gorilla) slides out of the body of the truck. The base of this assembly has 3 batteries that you'll need to pry out and replace.
Posted on Dec 02, 2009
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 01, 2015 | Evenflo Exersaucer Triple Fun Active...
I need an instruction manual for the Evenflo Triple Fun model #6231711 (manufacture date unknown - sticker is missing).
Here's an article that outlines the steps for converting the Evenflo Exersaucer to stage 3. It has photos and videos. Also, if you compare your end cap with the ones in the video, you'll see whether or not your end caps were replaced. How to Convert the Evenflo Exersaucer into Stage 3
Nov 27, 2011 | Evenflo Exersaucer Triple Fun Active...
I am needing an instruction manual for an Evenflo Exersaucer Triple Fun 25800496 08/06
hi
here is a page link to instruction download
near to bottom of the page
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
Oct 26, 2010 | Evenflo Exersaucer Triple Fun Active...
How do i put the seat back on my evenflo exersaucer
There are several models of exersaucers, but hopefully the seat attachments are similar. Here is a video from Evenflo showing how to assemble the product. This might help you.
http://www.evenflo.com/resource.aspx?id=467&rcid=19
Sep 29, 2010 | Evenflo Exersaucer Triple Fun Active...
I'm looking for an online assembly manual for my evenflo exersaucer
You can try this link. It will be helpful if you know the model number to the exersaucer you have. https://plweb.evenflo.com/replacement_parts.aspx
www.evenflo.com is a good website check it out it has a lot of helpful information. Please tell me if this works for you ok.
Thank you
May 04, 2010 | Evenflo Exersaucer Smart Steps 6161812 1...
Need to know how to fold down evenflo excersaucer! I have an excersaucer and no manual. I want to fold it down so I can get it in the car.
I can understand your frustration. Try this website https://plweb.evenflo.com/replacement_parts.aspx You would have to find out the model of the exersaucer you are using. There is also a number on this site that you might be able to call for assistance or for them to send you another manual. Let me know if you have any luck.
Thank you
May 01, 2010 | Evenflo ExerSaucer SmartSteps Active...
I lost the instructions to our evenflo exersaucer 3-1
if you go on the evenflo wesite. you should be able to type in the product you purchased,then a list of options should come up one being the instruction manual which is downloadable or read from screen.
Sep 12, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Exersaucer part
check
       https://plweb.evenflo.com/product_detail.aspx?prodid=9941
or
       https://plweb.evenflo.com/product_detail.aspx?prodid=12719
main parts for your model
       https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6161521&txSearchDOM=4/26/2005
Nov 14, 2008 | Baby Gear
Exersaucer seat
Evenflo - Exersaucer Instructions
25702569.pdf
https://plweb.evenflo.com/ShowDocument.aspx?ManualID=234
Dec 30, 2007 | Evenflo Baby Gear
Toys Logo
54 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
