TAPPAN FURNANCE FG6RL TRIES TO COME THEN I GET ERROR CODE 2
My Tappan TEF351EVM gives error code DR when I try to turn on the oven. What is going on?
dr is a door latch error, part 316405800. go here click on body and look at part number 18
/www.searspartsdirect.com/model-number/TEF351EWM/1269/0124111.html?searchType=modelSearch&q=TEF351EVM&searchTerm=TEF351EVM
this usually happens from using the self clean mode
Dec 04, 2017 | Tappan Kitchen Ranges
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
Tappan range error codr f5
Hello,error code f5 means temp too hot Replace oven temperature sensor
Thanks
May 26, 2010 | Tappan 30IN ELEC IGNa Oven
The heil furnance ignitor module error code
Remove the cover from the control box,there's a guide posted inside to trouble shoot the codes.
Jan 02, 2010 | Cross Furnace Draft Inducer Blower 115...
Our electric tappan dual radiant baking and roasting oven is beeping and giving an f1 message
Hi gracie7773,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2009 | Tappan TGF320 Gas Kitchen Range
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Tappan gas range tgf355 error code f1; what does it mean?
Where can I find the manual of the parts of the rear box of a Galloper 4X4 year 2001
Jan 19, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan stove
f-1 error code is the control failure error.replace the electronic control board.hope this helps thanks and Godbless
Nov 02, 2008 | Tappan TGF363 Gas Kitchen Range
Unlock my Tappan Gas Over Door?
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Aug 03, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan gas range is beeping a code
This is what f 2 means for Tappan:
Nov 15, 2007 | Tappan TGF657 Gas Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
