Question about DreamGear Lava Glow Wireless Controller Without Rumble for Playstation 3
How to use the turbo button on a dgps3-1394 - DreamGear Lava Glow Wireless Controller Without Rumble for Playstation 3
Model #ess25lgpaww ref section too cold turbo light will not go off ,fan goes off and on normal but lite stays on it dont freeze everything but it freeze in fresh food items fruit juice and lettuce
That sounds like a thermostat problem, but I wonder why the Turbo light won't go off.
Here is the Service Manual for your appliance
https://www.manualslib.com/manual/575785/Ge-Gss20.html#manual
This is your Instruction manual and it says if you press the Turbo Mode button, it will run in Turbo Mode for 8 Hours and then you have to press it again after 8 hours to get out of Turbo. Have you tried pulling the plug to get out of Turbo Mode. It chills the compartment to 1'C, so that would certainly ruin a lettuce!
Details are on Page 5.
http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/25_and_27.html?p=5
Dec 18, 2016 | Refrigerators
[VOLVO s60 2001 turbo] My steering wheel buttons issue not working
Is the vehicle fitted with the standard stereo fitted by the manufacturer?
If not, then there is a strong chance that these controls are not compatible.
Nov 18, 2012 | 2001 Volvo S60
Pleomax keyboard pkb 700b shortcut does not work
look below the enter key one turbo key also available
if you want to use three of these buttons like power off,sleep,etc
press turbo key and then press one of these its really working and very quite
Amrit
Jun 13, 2012 | Samsung Pleomax PKB-700B Keyboard
just hold the button you wished to be turbo-fied and then press the turbo button on your controller. (try it out on a FPS game like Black Ops hold the triangle button to switch your weapon and then press the turbo you'll realise the difference cause it will keep switching back and forth on it's own and real fast to boot O.o)
Nov 16, 2010 | DreamGear Lava Glow Wireless Controller...
Infinite play wireless controller turbo
I believe that it's a typo. You can only use turbo on one button at a time. Try it.
Press and hold the Turbo button, and press the button you want to use turbo with. If it doesn't work, your controller could be faulty and you may have to return it.
Nov 10, 2009 | Intec PlayStation 3 Infinite Play Wireless...
Installed a new okidata microline 320 turbo dot matrix printer and now the tear/set button does not set the paper where i need it to as my old printer did. How can i change the tear line setting?
Make sur that the paper length is correct in the settings. With paper in the printer hold down the "SHIFT" button then press the "SEL/MENU" button. The "SEL" indicatr will light up. Now press the "PARK" button, a settings page will print. Select your paper length you require by going through the settings, if you press the "LF" button it wil take you through the different groups of settings, the "FF/LOAD" button wil take you through the different items in the groups and the "TEAR" button will change the settings on the different items. To save the new settings hold down the "SHIFT" button and press the "SEL/MENU" button.
Aug 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
How do i get the turbo button to work ??
Only some games can use the turbo buttons. unfortunately i dont know what game suse them but i know that most of the call of duty games work with turbo for rapid fire.I think Grand Thedt Auto can use the turbo button aswell.
Aug 14, 2009 | Sony Wireless Controller for PlayStation 3
No instructions for programming
I can't figure out how to program the thing either.
As for the turbo, you hold the turbo button down while selecting the button you want turbo for. You hold clear and select the button that has the turbo to turn it off.
Mar 05, 2008 | Intec Turbo Shock 2 (G7000) Game Pad
Intec xbox controller
hold the clear button and press the button that is is turboing
Mar 03, 2008 | Intec XBOX CONTROLLER- PRO MINI CONTROLLER...
Error: Will not print
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Feb 20, 2008 | Dymo LabelWriter 320 Thermal Printer
DreamGear Lava Glow Wireless Controller Without Rumble  for Playstation 3 Logo
Top DreamGear Video Game Consoles & Games Experts
James Wishart
Are you a DreamGear Video Game Console and Game Expert? Answer questions, earn points and help others
