New instruction manual for coleman evcon model cpcp0301BA
22yooper
  • 828 Answers
SOURCE: Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
Posted on May 09, 2008
chillmaster
  • 104 Answers
SOURCE: i have a coleman evcon
R-22
Posted on Jun 23, 2008
  • 306 Answers
SOURCE: Coleman Evcon no fan when in heating mode
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Posted on Nov 30, 2008
  • 588 Answers
SOURCE: I had a coleman evcon installed in 1997. model
If you go to the top of a fixya page they have a search bar just search for coleman evcon instruction manual and you will get some help from one of fixyas experts.
Posted on Aug 23, 2009
  • 674 Answers
SOURCE: I have a coleman evcon system model BRHQ0301BC.
I don't have a manual but you need to check the fan capacitor and the fan motor windings with a multimeter. If the capacitor looks swollen then it is probably bad. Replace it with one of the same rating.
Posted on Jun 08, 2010
My Coleman Evcon furnace blows cold air even when the unit is turned off. How do I stop it from doing that?
Hello Rhonda Killalea,
On MOST furnaces built since 1960. there is provision
for the BLOWER on the old type THERMOSTATS.
BLOWER SWITCH ... has two positions
"ON" and "AUTO"...
(turn blower from on to "OFF" (or correct wiring)).
"AUTO" is the POSITION your thermostat NEEDS
to be on...
Only then will your heater's blower be under
control of those internal temperature controls.
I am including a SAMPLE page from the OWNER's
MANUAL... (a wild guess of which "EVCON" model
you might have)...
Without YOUR MODEL NUMBER... your answers
are going to be completely generic (pretty useless).
You will also need to disclose what model
THERMOSTAT you are using... while you are
LOOKING...
Try to note the FUEL you are using, HEATING
or HEATING-and-COOLING...
ELSE... my only suggestion would be to look
at the WIRES... note their color and CREATE
a TRUTH TABLE between the "typical" R,G,Y,& B
wires ( telephone wires ) and the ACTUAL
SCREW-TERMINAL designations...
Black, Brown, Red, Orange, Yellow, Green, Blue,
Purple, Gray & White... industry colors for
the possible TERMINAL designations... (and more)
THEN...
Go to the HEATER (air-handler or compressor)
terminal block and VERIFY .... The OLD FASHION
Red, White, Black and Green have a TERMINAL
MATCH from the thermostat to the HEATER.
Hope this helps...
Carnac the Magnificent
https://www.manualslib.com/manual/500880/Evcon-Eb-Series.html?page=2#manual
Evcon EB SERIES Owner Manual Page 2
Feb 20, 2018 | Coleman Heating & Cooling
What year is my Coleman A/C model # CPCP0301BA serial # 010216816
Either 2001 or 2002. Google coleman serial number diagnostics.
Jun 25, 2017 | Coleman Heating & Cooling
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
Coleman evcon four flashes on indicator...fans work... won't fire
Hi it could be the pressure switch clean the back of the fan control sensor, and the flame sencer
Feb 19, 2010 | Tools & Hardware - Others
I had a coleman evcon installed in 1997. model no.BPCH0241BA serial no.960384813.How do i get new instruction info? I cannot find mine. thanks deb
Aug 20, 2009 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
193 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
