Question about GTO Inc. / Mighty Mule Gate Opener Battery Heater
Mighty mule 500 constant beeping and gate wont close
4 Suggested Answers
  • 4 Answers
SOURCE: my mighty mule gate opener
In order to provide a solution to the problem, we need to know what it's doing. Does it start opening? Not open at all? Act like the battery is low.... I have one of these and it hasn't been non-problematic..
Posted on Feb 10, 2011
SOURCE: Mighty Mule 500 motor repair
Try Mouser.com part # P6KE16CA 36 cents a piece.
Posted on Jul 09, 2012
sittingducks
Condensation inside the arm shorts the limit switch in the rev counter board in cool damp weather.
Open the arm, dry the board and mop up the condensation inside the casing.
The solder contacts to the limit microswitch will corrode over time, and the board will eventually need to be replaced. Part RVCTBD50-E or similar.
Posted on Jun 18, 2016
Gate beeps when turned on and opens on its own mighty mule dual gate
There are limit switches that set the open and closed position and also a sensor for obstructions. Check those items for shorts and proper connection
Feb 10, 2017 | Cars & Trucks
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
Jan 01, 2016 | GTO Mighty Mule Automatic Gate Opener For...
Why is my mighty mule FM500 gate opener opening by itself?
Cathie,
Thank you for using GTO Products. If the gate opener appears to be opening by itself, then it's receiving an input from an accessory such as a transmitter, keypad, push button, exit wand, photo beam, loop detector, telephone entry system, etc.
By disconnecting these devices and reconnecting them back to the system one at a time, we can use a process of elimination to determine which device is causing the problem.
If you still need assistance, please call our tech support from the gate so we can help you troubleshoot. You can contact us at 800-543-1236 Monday - Friday from 8:00 AM to 6:50 PM EST
Technical Support
GTO Access Systems, LLC
Jun 29, 2014 | GTO Mighty Mule Automatic Gate Opener For...
Jan 12, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Does anyone repair pc boards for the Mighty mule gate openers?
Hello, im sorry to hear that you are having trouble with your gate opener. but it depends, on if your opener is still under warrenty and how the board got damaged, GTO "which is the manufacturer of mighty mule" is very picky about returning goods, so you MIGHT be able to get it replaced, but just getting it repaired is out of the question because of the components being heat sensitive and having software in the board, if you have more questions please email me a jasonruis123@yahoo.com
Dec 17, 2009 | Gates Deer Fence: Mighty Mule Driveway...
I have a mighty mule gate opener model number 352 and the cycles only open and close two inches. How can I have it properly open
Check the STALL FORCE setting on BOTH openers, check for gate obstructions broken gate hardware. OR your limit settings have been erased, but if none are the problem that you have a broken REV COUNTER which is inside the arm
Oct 18, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Schematic for mighty mule 502, lighting hit gate opener and now it does not work have replaced parts of foil runs and blown capaitor
Well this is a BAD situation, because your opener was NOT grounded, you will have to replace the Circuit board, but since this damage was caused by an act of god "nature, being lightning struck" Than GTO, "mighty mule" will probably NOT replace the board leaving you to BUY new ones, which are about $100 to $200
Sep 29, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Gate open and beeping,it will not close
Well if your board is getting power and the power supply is ok, but when you try to activate the opener, and do not get a response, than you have a faulty board, im Guessing you have a GTO 1000, Mighty Mule 700, or Mighty Mule FM500 series
Mar 13, 2009 | GTO Inc. / Mighty Mule Gate Opener Battery...
GTO Inc. / Mighty Mule Gate Opener Battery Heater Logo
159 people viewed this question
Top GTO Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a GTO Pool and Spa Expert? Answer questions, earn points and help others
