Question about Humax PVR9300T HD DVR
Message on tv the terrestrial antenna is short circuited how do I get it to go away
I have a TV and no cable. how can I watch TV.
You could purchase an antenna and get the local stations
Dec 31, 2017 | Televison & Video
I have a Seiko 50 inch flat screen tv were on the tv do I hook up a digital antenna
All terrestrial broadcast inputs go to the co ax input port, the TV will auto sort between analogue and digital inputs.
Jan 19, 2016 | Televison & Video
Terrestrial antenna is short circuited
In the set-up menu, switch off 'antenna power'.
Jul 29, 2015 | Televison & Video
What does the message 'Terrestrial antenna is short-circuited' mean?
It means that 'Antenna Power' in the Installation menu is switched on when it should be off. This is only required when sending power to a mast-head amplifier.
Sep 09, 2012 | Humax PVR9300T HD DVR
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
I am trying to use a Panasonic Showstopper DVR
It records on one channel only, not a tuner itself...........
May 24, 2010 | Panasonic PV-HS2000 Showstopper 30-Hours...
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
Toshiba 65 inch theaterwide
On any tv, first you must have two feeds coming in. That means either your tv must have two video cards, or your cable/antenna box must have two in order to se PIP. From there is a peace of cake... you push one button on your remote control and ....voila. Most tv's will have two video cards, one tor terrestrial antenna and one or more for cable/dish,.
Oct 28, 2008 | Toshiba 65H81 65" Rear Projection...
Humax PVR9300T HD DVR Logo
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
