Question about Electrical Supplies
Mastercraft 3250 watt generator brand new won't start has a wire unhooked is this the prob
2 Suggested Answers
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
Where can I get a wiring diagram for a 3250- watt generator?
go google and type in-- schematics wiring diagram for watts 3250 generator set-- and if one is available it will be pdf version download
Jan 04, 2016 | Watts Electrical Supplies
I have A Steele 3250 watt generator 196 cc OHV engine gas powered and it wont start.what do Can l do too fix it?
turn on the ignition switch
check and bring the oil to the correct level
check for spark
check choke operation
check low oil level switch is operational
Apr 18, 2015 | Electrical Supplies
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
Powermate generator 3250 runs for hours then chokes out runs rough
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Oct 27, 2012 | Powermate Portable Generator: 3250-Watt...
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Just bought a generator 5000/6250 style but my husband can't pull the recoil handle. i think it's stuck so we can't test the generator. the unit was shipped from california to the philippines. pls advice...
Try removing the spark plug and rotating the engine by hand.
It could be just a little corroded from shipment over the ocean.
But once you have it loosened up and the oil circulated, it should start much easier.
Make sure it has oil in it, because sometimes they drain the oil before shipping.
You could also have someone else try the starter rope. A new engine can be hard to start.
Oct 04, 2010 | Briggs & Stratton Briggs and Stratton...
What is 3250 wattage i am looking at a gaggia machine to buy and it says it is 3250 wattage will i need special electrity power thanks
Hello and Welcome to FixYa!
Please explain your query a bit more... What I understand is that you need to know what that 3250 W means. Actually this the power (approximately maximum) that can be generated using that equipment... Every electrical equipment consumes certain power e,g. Ceiling fan ~100W, Iron ~1000 e.t.c. You wouldn't need any special electricity power as such.....
Regards....
May 24, 2010 | Briggs & Stratton 3,250 Watt 6.5 Hp...
Electrical Supplies Logo
156 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
