Question about Coby DP-758 Digital Picture Frame
Pictures want go in order and it freezes on a couple of pictures. Want show all pictures that i have downloaded
Picture freeze,long tme to restart does it again
Unless you have good / fast access to the Internet (or wireless or 4G network), it may take a long time to download a movie to your device. If the speed of download is slower than the speed of the play, the picture freezes ... essentially, it is waiting for the completion of the download for the next few frames (of the movie). That is why the picture freeze .... and it will start again after sufficient data has been download to continue / start playing (the movie) again.
Apr 30, 2013 | Cricket Wireless Cricket Crosswave WiFi...
After I shoot a picture the camera freezes up. I have to power off and up a couple of times to get it back to shoot mode. It does not store the image when it freezes up.
Can you power up the camera don't take a picture but move around the functions and view pictures on the LCD screen? If the camera does all the functions it's suppose to except hold a picture then I'd say the memory is at question. You might not have a memory card installed in the camera and it's working on the Internal Memory which is now full or not able to load another picture. If there is a memory card in the camera it might have the protection switch in the lock position which then would shift the picture storage to the internal memory. You need to check to see if there is a memory card in the camera if so make sure this card is in the unlock position. If the images are on the internal memory then you need to transfer the internal memory pictures to the memory card for download to the PC. Make sure the memory card is unlocked and formatted to the camera after you download the pictures to the PC
Jan 08, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
The picture freezes and there is no sound until the picture stops freezing. this happens every couple of minutes.
First of all, you certainly have three bad capacitors in this TV. CX3416 is a 25 volt 100mf cap that is bad. Cx 3218 is a 160 volt 2.2 mf cap that is bad and finally C3460 is a 25 volt 220 mf cap. The C3460 is the culprit that is stopping the feed to the audio out put IC. This cap is near the audio IC. It is attached to a large heat sink. Resolder the pins on this IC as well. And after replacing the capacitors, be sure to inspect all solder grounds and resolder as necessary. Hope this helps. Thanks for asking and show a few hands of support.
Dec 19, 2010 | Zenith B25A24Z 25" TV
Picture goes off and on every couple of seconds
If you are hooked up to a HD source if the signal is too high will cause this to happen. Normally this will happen due to signal interuptions such as signal being low will cause freeze, too high will cause it to go out and cause the TV to show default blue.
Good luck to you.
Sep 20, 2009 | Memorex MLT1921 19 in. LCD TV
Picture freezes after only a few minutes of being live
Normal 0 Web Camera’s have to besetup on the program they are to be used with. Just installing the camera on your computer does not set it up tobroadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hopethis helps. Bud
Feb 19, 2009 | Microsoft LifeCam VX-3000 Web Camera
My picture freezes after only a few minutes on a call
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
IQ Digital Picture Frame
I have an IQ Digital Photo Frame but the manual is in French I would like to be able to download the English version can anyone help please
Nov 19, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Freezing when hitting downloaded graphics
well you will have to try reflashing the firmware on the phone also upgrading it or you can eprom the phone *2767*3855#
Sep 24, 2007 | Samsung SGH-d807 Cellular Phone
Need Help-Nextel i850 keeps freezing up between opening and closing
go to motorola.com/iden
click united states
click support
click software downloads
(if you have pictures and videos download iden media downloader to retain them)
click software upgrade
click your phone model
make sure you select a date within a year for the warranty info
you will need a data cable to make this work
try to redownload the software to your phone
this might help
Thank You
Sheeraz Khan
Masalama
May 25, 2007 | Nextel i850
Coby DP-758 Digital Picture Frame Logo
19 people viewed this question
Top Coby Photography Experts
richie46
Are you a Coby Photography Expert? Answer questions, earn points and help others
