Question about Pleasant Hearth Alpine Black Fireplace Glass Door
Pleasant hearth vff ph20d remote manual - Pleasant Hearth Alpine Black Fireplace Glass Door
Pleasant Hearth WS-2417-B stove. Why doesn't air control work?
then call the installer back , there has to be a damper in the pipe going out ,
Oct 31, 2015 | Home
Smoke and soot from my pleasant hearth stove
Your chimney must be properly installed above the roof line to prevent downdraft. The soot issue may be cause by burning wood that is too green, not dry enough to burn clean.
Safety is a concern when using a wood stove in your house. Be informed about the dangers of Carbon Monoxide Poisoning.
http://carbonmonoxidedetectoralarms.com/
Carbon Monoxide Detectors are mandatory by law in some states. Protect yourself and your family.
Amazon com carbon monoxide detector Electronics
Mar 23, 2014 | Pleasant Hearth Home
Making a noise in my pellet stove
Is the noise constant or intermittent? Constant will be a combustion blower that's bad. Intermittent is probably an auger on its way out.
Mar 17, 2014 | Pleasant Hearth Home
Auger is not getting power
The auger may be jammed. If you cant wiggle it then it probably is. If not then you have an issue with a sensor....ie an air leak, bad igniter, heat sensor.
Mar 02, 2014 | Pleasant Hearth Ghp Pellet Stove Large...
My remote is beeping on my gas fireplace model Vff-PH32DR
Check the batteries. in the receiver and remote.
Jan 23, 2014 | Pleasant Hearth Home
Need themostatic remote control for model vff-ph32dr
What brand of camera is this? and a new kind of remote controller? I know infra red controllers and radio, but never heard of Thermostatic ones. I wonder.
Nov 11, 2013 | Cameras
Farberware rotisserie manual
All Farberware "Open Hearth" Broiler, Rotisserie and Shish Kebab manuals are available for download at http://openhearth.info
May 07, 2010 | Grilling
Pleasant Hearth Alpine Black Fireplace Glass Door Logo
364 people viewed this question
Top Pleasant Hearth Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Pleasant Hearth Hardware and Accessory Expert? Answer questions, earn points and help others
