What is the wall screws for a Toshiba 50L1350UC
2 Suggested Answers
  • 15 Answers
SOURCE: How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Check the input panel on the rear for one to two black screws that need to be removed. Some Toshiba sets also have the base attached through the cover, so the base also needs to be removed first ald then you can remove the back cover.
Posted on Aug 08, 2016
My toshiba 50l1350uc has sound no picture
In most of the case, the problem is defective back lights LED strip.
May 30, 2017 | Toshiba Televison & Video
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
Im painting and need to remove the 42 in Toshiba off the wall, but want to make sure im not goin to break anything. What screws am I suppose to take off?
I have just done the same, though I have a panasonic.You need another person to help you lift it of the wall which will show the bracket on the wall.Take the screws out from the bracket. Leave the other part of the bracket which is screwed onto the back of the tv.
I hope this helps.
Tony
Jan 18, 2010 | Televison & Video
Wrong screws
Hey there,
The screws for the tv are metric.
I would suggest the screws supplied with the shelf are not metric.
Try some new ones.
Sep 13, 2009 | Toshiba REGZA 46RV530U LCD TV
I have a toshiba dkt2010-sd that I need to mount to the wall
The base is removed and turned 180 degrees and put back on phone notice the slide tabs are in correct position and can noe be hung by screws or a wall jack. Where the cord plugs in there is a breakout tab, that is the insert to hold the reciever on the phone when hung up.
Sep 09, 2009 | Toshiba DKT-2010 Corded Phone
What is the wall mounting screw diameter for a Toshiba 40xv645u
dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Jun 14, 2009 | Televison & Video
Can i wall mount this
Usually, UMC include the screws already screwed into the wall mounting holes that you should use to attach a wall bracket. This is so you dont then go and use longer screws often supplied with wall mounts that are way too long and can damage the parts inside the TV.
Dec 18, 2008 | Toshiba 20HLV16 20 in. LCD Television
Removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Nov 23, 2008 | Toshiba Televison & Video
Toshiba 26HLV66
you will need to remove the jack pack cover on the back of the unit (plastic cover), it should pop off, then remove the screws holding the stand on (should be 5 if memory serves).. after that the stand should slide away from the tv.
make sure your wall bracket kit can support the weight and that the screws you embed in the wall are using hercules hooks, anchor bolts, or something similar... last thing you want is a dead tv and ripped up drywall.
hope this helps,
trin
Nov 16, 2007 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
