Question about Makita LXT202 BHP451 18 Volt Hammer Drill & BTD140 18 Volt Impact Driver Lithium Ion Combo Kit
My Makita drill driver slips under a load. Is it the clutch and how do I repair or replace the part?
  • 14 Answers
SOURCE: makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Posted on Mar 04, 2008
  • 313 Answers
SOURCE: makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
Posted on May 29, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
rowdy45176
  • 2176 Answers
SOURCE: makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Posted on Jan 23, 2009
jj505
  • 195 Answers
SOURCE: clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Posted on Mar 29, 2009
Have a new Makita DF330DW and the clutch started slipping out of nowhere. The drill will turn in fwd and rev but as soon as there's any resistance, it quits spinning. I have run it through all of...
Definitely a faulty clutch. Take it back to where you bought it (if it was recent), otherwise send it or go to a Makita Service Centre.
Hope that helps
Jul 10, 2011 | Makita DF330DW 108Volt Ultra Compact...
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
Mar 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
My Makita 3.0ah cordless drill does not drive anything when I put pressure on it. Would the clutch be worn and if so is it easy to repair?
Clutch is part of the transmission assy - yes it is about the only thing that it can be causing your issue. It is a fairly inexpensive and easy fix on Makita - the worst part is removing the chuck.
Jun 25, 2010 | Makita 18V 1/2"CRDLS Drill Kit
Makita 6349DWDE 18V Cordless Clutch
could be the clutch needs replaced, but I would check to make sure the high/low switch is fully engaged. Inside the clutch there is ring gear that could have the teeth rounded off I would go to Makitatools.com and type in your model number for a breakdown so you can see what you are getting into, they are not that hard if you are mechanically inclined and just watch how you do it.
Sep 23, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
18v makita bhp451 cordless hammer drill.clutch slipping
its prob stuck between gears one and two try a little wd40 on the gear selector switch
Jul 18, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Clutch slipping on cordless drill. need spare parts to repair.
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 8444d mxt drill
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita LXT202 BHP451 18 Volt Hammer Drill & BTD140 18 Volt Impact Driver Lithium Ion Combo Kit Logo
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
