I don't have the manual to program the SIMZ universal remote control, can you help me with the instructions to do so.
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
aprmaejun
  • 97 Answers
SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
  • 547 Answers
SOURCE: cant program my remote
I could type each step in and claim it's my own brilliance, but really you should just follow the steps at wikihow (transcribed from RCA's website)
If that works for you, please be sure to rate my answer as "helpful"
Thanks!
Posted on Aug 31, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Need setup instructions
Lorris, Check the attached links,easy to program remote instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Programming Your Universal Remote Control
How to Program an RCA Universal Remote Using Manual Code Search
How to Program Universal Remote
Apr 04, 2016 | Televison & Video
How do i program using one for all universal remote control?
How do i program Carla, Check the attached links, how to use and setup universal remote, instruction and guides, Good luck
How to set up universal remote
https://byjasco.com/sites/default/files/product/manuals/24914_Manual-v2.pdf
Apr 01, 2016 | One For All Televison & Video
I have a lm-1079 remote and i need the program codes for a Panasonic. Tv/ dvd/vhs combo can you help with instructions on how to program the codes to the remote..... Thank you
How do I program a GE LM 1079 - ManualsOnline.com
tv.manualsonline.com/...remote...remote/how-do-i-program-a-ge-lm-107...
Aug 24, 2014 - Question About Universal Remote Control Universal Remote LM 1079. How do I program a GE LM 1079... How do I ... Get the Manual Here.
Universal Remote Control Product Support ' Manuals
Jan 01, 2016 | Televison & Video
Need codes and instructions to program Sanyo universal remote B21309 to a Philips Vcr/Dvd player.
Sanyo universal remote b21309 manual - logo - Tuars.com
ititoso.tuars.com/sanyo-universal-remote-b21309-manual/
Sanyo Universal Remote B21309 Please help find the manual for Question AboutSanyo Universal ... RMT-D153a RM-AX4000 Manual PDF instruction manual.
Sanyo Universal Remote RMT-U100 User's Guide ...
tv.manualsonline.com > ... > Sanyo Universal Remote
Sanyo RMT-U100 Universal Remote User Manual. Page 1. Page 2. Page 1 ... TheSanyo Universal Remote Control features large glow-in-. the-dark basic .
Nov 01, 2015 | Philips Televison & Video
I have a "classic electronics" universal remote
I don't mean to be smart. but the best option for you is to go buy a new remote from wal-mart. As this remote sounds like it is an off brand remote and you will most likely never find the instructions for it.
Oct 07, 2012 | Televison & Video
I don't know what kind of universal remote I have there is no name on it, and I need to program it and don't know how.
download the instruction manual from : www.fitness.manualsonline. or www.retrevo.com
+download code; www.remotecodelist.com
God bless you
Jul 20, 2012 | Universal Remote Control Televison & Video
NEED MANUAL INSTRUCTIONS
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sony TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Oct 04, 2009 | One For All URC4110 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
