Question about Sharp AR-M237 Copier
Copier stuck on "please wait data is being cleared"
"Sim 66-10"; What does "The confidential data" mean?
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
Mar 01, 2015 | Sharp MX-2310U Color Printer : 2310U
Why is the DATA light blinking on Sharp model MX-2300N
If something is stuck in the rendering process this will happen. To fix it, first make sure the machine is in copy mode then press:
Pound, Star, C, Star
66, start
10, start
execute, yes...wait for a minute while it processes, then it will reboot.
this will clear out anything stuck in queue
Skelton Business Equipment Houston Copiers
Jun 02, 2014 | Sharp MX-2300N Color Copier
Why does my data light keeps blinking? My machine will copy but not print. Please help
The simple answer to this question is to perform an image memory clear.
Here is a video on that for newer sharps, from older sharps just press # * C * on the panel, then 66 start, 10 start, execute, yes.
Copier Collin Houston TX Copier and Imaging Expert
May 23, 2014 | Sharp MX-2700N Color Copier
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
My Printer ( HP Deskjet F2210 ) will not print. It is installed, plugged in, and has ink AND paper. I've waited several hours for it to print but it will not work. It's stuck in the queque, or...
Go to START then RUN and type services.msc and click on OK. This should open services window. Scroll down to on the list and look for Print Spooler. Click on STOP on the left pane then restart the service. This should clear put the stuck document in your print spooler and you should be able to print again.
Hope this helps.
Jun 14, 2011 | HP Deskjet F2210 InkJet Printer
Casio tk-1200 stuck on error E-04
Firstly, try a flag clear. This will not lose any of your data:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Turn key back to REG mode and try it
Nov 30, 2009 | Casio Parts Cash Register PC Desktop
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Aug 06, 2008 | Canon imageRUNNER C3200 Copier
Pixma MP780 Series All-in-0ne Printer
is it print test print direct without plug in computer. replace also data cable of printer .
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Canon CLC 2400
go into service mode and clear ram remember to copy the values before clearing or your dc controll is damage
Nov 29, 2007 | Office Equipment & Supplies
Sharp AR-M237 Copier Logo
341 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
