Question about Kettler Exercise & Fitness
Kettler pacer e6 fault - Kettler Exercise & Fitness
ercupa190
  • 12223 Answers
SOURCE: my kettler pacer show e7
adjust the reed switch see the diagram attached.clean, and tigh the connector very well. After you fix it RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: kettler pacer show the error 1
Dear Sir:
You can be fix it.
1) See the diagram attached, and adjust it, clean, and tigh the wire connector very well.
2) Test the input voltage for motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for the input voltage motor, if there are NOT, the board is faulyt.
4) However RUN the software calibration for diagnose, troubleshooting, and fix it.
Posted on May 06, 2012
ercupa190
  • 12223 Answers
SOURCE: my kettler pacer show e1
adjust the speed sensor see the diagram attached, clean it, and tight the connector very well.
2) test the input voltage motor, if there are the motor NEED repair
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Posted on Sep 10, 2012
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 28, 2012
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
I have an error on my treadmill: system fault DC6, how can i fix it without asking for service?
If you wish to get some details about treadmill repair and maintenance then check the following link
http://electro-medical.blogspot.com/
Sep 16, 2016 | Kettler treadmill Pacer
I am looking for safety key of KETTLER TREADMILL PACER
You might be able to cheat with a fridge magnet until you find one.
Mar 19, 2016 | Kettler Exercise & Fitness
I have Kettle pacer treadmill,when I press start button the display shows error DC 6 and belt does not move
have you kept the belt regularly lubricated ?
can't find this error code in manual
Nov 25, 2014 | Kettler treadmill Pacer
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
How can i oiling my kettler pacer belt ?
you dont oil it, you have to put treadmill wax on it, and you just put it under the belt on top of the deck at the front and the back
Apr 25, 2014 | Kettler treadmill Pacer
E1 error after start up.
Does the walking belt move for a brief moment, then immediately stop, followed by the E1 code? Or is there no belt movement at all when start is pressed?
Nov 27, 2013 | Kettler treadmill Pacer
Treadmill KETTLER PACER - dc6 system fault, what I
Check if the drive motor is working
Power cycle...if still do not function calibrate or call 877-805-1030
Aug 10, 2013 | Kettler Exercise & Fitness
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
ERROR CODE # 7
2)Alternative:
My kettler pacer show e7
Apr 29, 2012 | Exercise & Fitness
Exercise & Fitness Logo
73 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
