Kenmore washer model 3394715 wont drain - Washing Machines
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 351 Answers
SOURCE: kenmore 80 series washer. model #110.29812890.
This would be a lid switch i carry them in stock and can ship out today yet... whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 1122 Answers
SOURCE: kenmore model 417 94702300 stack washer dryer wont
bad lid switch-mike
Posted on Jul 30, 2009
  • 1937 Answers
SOURCE: Kenmore Washer Model#23812100 It wont speen adn
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site for your washer may have a section on the gearcase. Check in that section for a Neutral Drain repair kit.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
Posted on Oct 31, 2009
Testimonial: "It Was the "LId Switch ", this particulat top loader model , will agitate with the lid open however it will not speen and/or drain the water out...."
blueextc3221
  • 15935 Answers
SOURCE: MY KENMORE ELITE WASHER WON'T DRAIN.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Kenmore 3394715
For Leveling and balancing and proper set up of any appliances c consult with user manual for any set up problems
Dec 09, 2013 | Washing Machines
Kenmore 70 series model 110.20722990 wont drain and spin
It could be the timer or circuit board, until it is not draining, will not spin
If the timer or circuit board is OK, the you have a faulty drain pump or motor, to check this out remove the back panel.
Mar 12, 2013 | Kenmore 22422 Top Load Washer
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
My washer wont drain the water....It spins but wont drain
This must be a brand new Kenmore 20.6 cu. ft top freezer refrigerator. I have serviced over 10,000 refrigerators and freezers. Never once did i see one that had a washer, let alone one that spins but wont drain. Maybe you should try the washer forum.
Mar 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I want to know the production date of Kenmore 3394715, stackable washer/dryer combo.
The production date is determined by the SERIAL NUMBER on your appliance. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Kenmore washers are manufactured by Whirlpool. If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
Our kenmore washer wont drain
Try these
  3. Test the lid switch (some models)
  5. Inspect the drive belt (belt drive only)
pls rate my suggestion.......
Jul 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 series washer model 20922 wont drain
have you tryed blowing back the drain pipe to clear and sourse of fault,also is the water element heater working ok?it could be waiting at a thermostop position till its up to correct temp,hope this helps
May 27, 2009 | Kenmore 15944 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 3394715 stackable washer/dryer
Go to sears parts direct .com. You can pull down a schematic on how its put together.
May 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
