I have a flashing C:31:23 on my screen
That's what I will try and do. Here's what we need to do:
Sony® camcorders nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current camcorder models can only be returned to the original factory settings by pressing a small RESET button on the camcorder.
Older-model camcorders (prior to the year 2000) do not have a built-in rechargeable battery or RESET button, and require a manual power reset.
IMPORTANT: To determine whether or not your camcorder has a RESET button, or if model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camcorder.
Using a RESET button
Performing a manual power reset
If your camcorder is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Let me know how it turns out.
For more info on the trouble codes, look here:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=92061592&stateId=0%200%2092065814
Hi, this is a common problem with sony DCR-PC series camcorders. The cause is the loosening or loss of one of the rubber rollers inside the tape-deck mechanism. You can try tapping the top of your camcorder (where the flash shoe is located) and see if they problem goes away. Look inside your tape-deck and see if the rubber roller is still there, if you dont see a rubber roller, then the tapping may not work. Then your only solution will be to replace the rubber roller, which may be quite difficult as this part is hard to get since Sony no longer makes the DCR-PC line of camcorders. Another workaround is to use the tip of a can of compressed air (used to blow debris off keyboards, etc) you can buy at office supply stores. Strangely, the round plastic tip approximates the same size as the missing rubber roller, fits the metal spindle that holds the missing rubber roller perfectly and can be used as a replacement successfully to get rid of the dreaded C:31:23 message. Here's a thread that discusses this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
DCR-TRV22 Sony It is flashing a code C:31:23 what does that mean and a triangle is also flashing. I cannot get the tape to rewind or play. Can you help me
What is the brand/model of your digital camera?
