Question about Whirlpool Inglis IP4400 Washer
Adjust the door on a front loading washer whirlpool ifw7200tw
duby1990
  • 367 Answers
SOURCE: Whirlpool Duett Front load washer, DFL code door won't unlock?
Here are the steps to unlocking the door manually
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
  • 4 Answers
SOURCE: My whirlpool duet front load washer door leaks.
YOU NEED A NEW BOOT ON THE INSIDE OF THE DOOR. WHEN YOU OPEN YOUR DOOR THERE SHOULD BE A GRAY RUBBERY RING. AS A MATTER OF FACT, IF YOU MOVE THAT RING AND PUT YOUR FINGERS IN IT YOU WILL PROBABLY FIND A MISSING SOCK OR TWO! THAT RING HAS TORN AND NEEDS TO BE REPLACED.
JB
Posted on Sep 12, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
  • 58 Answers
SOURCE: whirlpool AWM6100 front loading - door open when not!
it's probably the innerlock, is the door locked?? if not it could be the innerlock
Posted on Mar 09, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Replaced bellow now washer beeps and won't start
door switch may need adjusted to make up for the thicker bellows
Sep 25, 2015 | Whirlpool Washing Machines
My front loading washer makes aloud noise and shakes terrible when it spins at mediun or high speed. model ifw7200tw
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 26, 2010 | Washing Machines
Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM6100 front loading - door open when not!
Mar 09, 2010 | Whirlpool AWM6100 Front Load Washer
Odor problems with whirlpool front load washer
Is the smell of mildew?
Run the washer on empty with beach and soap.
This is a common problem when the front door is left closed after use.
When the washer is not in use leave the front door cracked open. This will help in preventing mold & mildew.
Dec 12, 2009 | Whirlpool GHW9100L Front Load Washer
Can you adjust the door on the duet washer. I
You need to replace the hinge, sounds like it has worn out bushings.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Inglis IP4400 Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
