Question about Sharp Office Equipment & Supplies
I have a Sharp PG-F267x that has small white dots on the right side of the picture. What is wrong with it?
  • 29 Answers
SOURCE: xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Posted on Jan 18, 2009
  • 1093 Answers
SOURCE: no picture just a black screen with small white
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Posted on Feb 04, 2010
redrose19732
SOURCE: I have small whitr dots on my picture screen
I went through the same problem with mine started out as one ended with many Its the optical lamp board cost is $600 and some dollars for a model 73-733
Posted on Jan 06, 2012
  • 879 Answers
SOURCE: picture is slanted left to right.
Check and replace the main digital processor board. Synchronization problem, along with phase.
Posted on Aug 20, 2012
  • 483 Answers
SOURCE: my mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Posted on Mar 07, 2013
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
Mar 07, 2013 | Televison & Video
Thin white line on right side of tv intermittent
The only easy hope here is centering is off just slightly to the left and the line etc will show on certain scenes and or channels.
Not sure if this set has a centering in customer menu or maybe in the tech menu---a call to sharp might answer this for you.
Aug 28, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Dec 06, 2011 | Mitsubishi WD-73733 73" HDTV
Please help and solve me the problem. My Sharp Pg-B10s projector picture Upside Down.
The projector must not be used upside down. There is no way to invert the image because of this restriction.
Apr 08, 2011 | Sharp Notevision PG-B10S Multimedia...
Connecting my xbox 360 to a sharp projector
video plug to yellow video in jack, audio to red and white.
Jul 12, 2009 | Sharp Notevision PG-B10S Multimedia...
2 lines down the right side of paper - sharp 1641 CS copier
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Dec 11, 2008 | Sharp AL-1641CS Laser Digital Copier
Picture size
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Please read page 39 or in your manual page 38
Nov 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I get white dots upper left corner across the screen of set now I have a Sharp LC-37D40U LCD TV. Is it the pixels?
Hi Yabby,
If the dots are very narrow and jump about and you're receiving an analogue signal it could be teletext information. This is normal but is usually hidden off the top of the screen. You need to adjust the picture height to take them off the top.
Regards
Andy
Jun 26, 2008 | Sharp Televison & Video
Colors off
I don't think you'd like to write down all your settings. =)
Of course, make sure your Auto is set, this ensures you are allowing the camera to make all choices for you. If the pictures still don't come out correctly, you may need to have the camera serviced.
If pictures can be taken in Auto mode, but not in (P)rogram mode or others, then give it a try to RESET all options and "start over" like "in the beginning".
The possible reasons are Pg. 91 of the manual:
  • White balance is not on Auto, or incorrect for the lighting conditions. Pg. 92-94
  • The wrong metering makes the lighting evaluation go funny. Pg. 95
  • Bracketing could be set wrong, which makes takes two or three extra pictures with compensation +1 and -1 of your current settings in order to try and capture a better picture at the instant of the original. Pg 116-117 (less likely though)
  • Exposure compensation is set too incorrectly for the conditions. Pg. 108-109
You can find these steps on page 119 of the manual.
To do this follow these steps:
  • Choose a program mode
  • Press the Menu button
  • Goto the bottom of the menu list to choose Reset All
  • Select it and reset all settings
This might have to be done for each program mode.
Please rate a FixYa! ThankYa!
Nov 13, 2007 | Nikon Coolpix 4500 Digital Camera
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
