Question about Android Apps
Playstore missing - Android Apps
How can I upgrade to a supported browser on a Alcatel one touch960c ?
there should be an app called playstore on your phone
you need a gmail account www.gmail.com to use playstore
set up an email account
Set this up on the phone when you access playstore and get asked for an email address.
Then search for a browser
http://www.androidauthority.com/best-android-browsers-320252/
Aug 08, 2017 | Alcatel Cell Phones
How do i install playstore on my laptop
Hi..I can install playstore on laptop..I have done this on my Dell laptop; if you want ,I can take remote access of your system and install playstore, one time charges USD 20; pay ONLY if the issue is resolved.
Call me at:OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number in USA ).
My Name is Harry.
Jun 23, 2017 | Cell Phones
How to get back my app that i hide it
if you're using android, search for your missing app on playstore. it will the app's status there. you can uninstall the app, and install it again
Oct 17, 2016 | Huawei Cell Phones
The playstore on my tablet do not want to open sins i did the software upgrade
In order for your tablet to have a working Playstore, it must be compatible with Playstore.
The reason that I? telling you this is because a lot of people buy a used tablet, with third party software in which force a Google app into the tablet.
Since there is no detail about the tablet, I can only guess.
Go to settings>app. From here search for Google Services, if there is none, then it means that you must install it for your device or update it. If there is none for your device, then it means that your device does not support Playstore.
Jun 06, 2016 | Tablets & eReaders
I had to reset it because it would not go past the blue screen. Now i dont have adobe or anything like that on it. I tried using playstore, it wont work, how do i fix it?
Sounds like you did a hard reset which may have deleted all your settings and passwords.you will have to sign back into google for playstore to work then download all the apps that are missing.you need to find out how to do a soft reset which will fix frozen tablets without erasing data.
Nov 16, 2015 | Tablets & eReaders
Launcher is missing
Launcher is Missing is it a luncher app you downloaded from the playstore or is it the default launcher of your phone because if its just an app that you downloaded from the playstore its missing because a factory reset will erase all your data and apps
If its the dufault launcher is your phone rooted?
Did you perhaps uninstall the default launcher using a root tool like link to SD?
If you have uninstalled your default launcher then you would have to flash a stock rom from your phone's manufacturer or download a custom rom from the internet
Sep 03, 2015 | Nextbook Premium 8 Se Android
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Mar 07, 2015 | Tablets & eReaders
My tablet don't what to go in to my playstore what should i do?
Make sure you have a wifi connection. Playstore is on the internet so you have to be able to access the internet.
Also, if the Playstore app that came installed on the tablet is lost or needs re-installed for some reason, then you won't be able to re-install it on your tablet unless you also have gmail running on the tablet or google+ or some other app that Google can use to identify you as the tablet owner.
Feb 02, 2015 | Tablets & eReaders
How do I find missing icon from playstore App. downloaded ?
hold down spot on screen it may be a app or a widget. Search through both
Oct 20, 2014 | Cell Phones
No connectiont to google Play store
most of the time weak signal on your device.. switch off the wireless connection. try clearing the cache for Playstore through the running services settings on your device. End the playstore process then turn off the phone then on again, activate your wireless or data connection and once you confirm you have strong connection, try playstore again
Aug 09, 2014 | Cell Phones
Android Apps Logo
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
