Question about Samsung WF8704RSW
My samsung Samsung WF-8704 display code OE. What does it mean?
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: Describe your samsung wf-b 1061 error code 5E
Error code 5E is the code telling you that you will need to clean the filter. After you clean the filter the code will go away.
Posted on Dec 19, 2010
What do you do when the OE code comes on , I was starting and hitting spin . But now it want do anything
If it is a samsung look in the back of the owner manual it tells you the code meaning. It could be door seal, load dispersal.
Dec 13, 2016 | Washing Machines
Samsung washing machine displaying dE
Make SURE code is dE because if it's oE = it indicate a problem with WATER level. from my Manual "trouble shooting " page. o.k.Ray
Feb 09, 2015 | Samsung Washing Machines
WF328 AAG OE error code...how do reset this? or can I reset this?
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 24, 2011 | Samsung WF328AA Front Load Washer
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    Describe your samsung wf-b 1061 error code 5E Problem
    Dec 19, 2010 | Samsung WF317AAG Front Load Washer / Dryer
    MAYTAG NEPTUNE ERROR CODE OE
    The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
    Sep 11, 2009 | Maytag Neptune MAH9700 Front Load Washer
    Samsung WF8704RSW Logo
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
