Question about Sanyo AVM-2506 TV
Schematic for a sanyo avm 2506 tv
Coul you tell me an adress in internet where I can find a schematic for a sanyo avm 2506 tv.
  • vickgv Oct 03, 2007
    I had to buy a schematic in Mexico, D.F. close to my house. Thanks anyway.
    Sergeant:
    Champion:
  • 346 Answers
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Schematic for a sanyo avm 2506 tv. please check www.serviceinfo.com for schematic diagram.
Posted on Sep 28, 2007
  • manahar modern Oct 03, 2007
    does not mattar where you are staying it is available in free from given web site.
    as you are a tech. person as you require schematic diagram.
    you can download from web site sanyo ckt it is not neccsary that you will get the same ckt but by seeing 2 3 ckts you will get the solution.
    web address
    www.serviceinfo.com
    hope this will help.
SOURCE:
T.V ONLY HAS NO INPUTS
U need an ipad audio/video connector. One end is the plug at the bottom of the ipad, the other end is a red/white/yellow tv connector. Get a genuine apple one, not one made by other companies, or they wont work, apple has blocked 3rd parties from certain items, and thats one of them. It costs $50 new, or you can find it on ebay used for alot less, just make sure its not a cheap knockoff and its the real one.
Mar 03, 2013 | Sanyo AVM-2506 TV
Schematic diagram for sanyo tv AVM-2979P
Only two choices here aside from Google the model number with "service manual" is to contact Sanyo or look to see if the set is covered by a Howard W. Sams photofact manual.
May 15, 2012 | Sanyo AVM-2509S TV
Where do i plug in my dvd player to a sanyo avm 2506
Get RCA cables they come in 2 or 3 conductors, Yellow andWhite for Mono and Yellow, White and Red for stereo connection.Connect the one side of the Yellow cable to where it saysVideo OUT on the DVD.
Connect the other side of the Yellow cable to where it saysVideo IN on the TV.
Connect the one side of the White cable to where it saysAudio OUT L on the DVD.
Connect the one side of the White cable to where it saysAudio IN L on the TV.
(optional) Connect the one side of the Red cable to where itsays Audio OUT R on the DVD.
(optional) Connect the one side of the Red cable to where itsays Audio IN R on the TV.www.aaatvservice.com
Jan 26, 2012 | Sanyo AVM-2506 TV
My kid ran a magnet across the screen now there's a purple blotch along the top of the screen.
The TV needs to be degaussed.
There is an automatic degausser built in but it may NOT be strong enough.
Try this: Turn off the TV and let cool for 10 minutes. Then turn on for one minute.
Repeat the previous sequence until screen is clear of blotches.
The cooling period re-arms the degausing circuit.
If this doesn't fix it adequately, you need to find a TV repairman that has a degausing coil... these are getting a bit rare now. It would take him ten minutes with the coil to fix it.
Dec 25, 2009 | Sanyo AVM-2506 TV
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Mar 06, 2009 | Sanyo AVM-2506 TV
Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Sep 27, 2007 | Sanyo AVM-2506 TV
Hibhh
That doesn't mean anything
Apr 27, 2007 | Sanyo AVM-2506 TV
TV sounds like power up for few seconds then goes off
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
Mar 04, 2007 | Sanyo AVM-2506 TV
Televison & Video Logo
1,098 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
