Question about Panasonic Workio DP-4530 Copier
Crooked Copies Hi. I have a workio dp 4530. I recently changed the toner and when I did, every copy now comes out crooked. The original is straight on the glass and the paper tray is full of paper that is loaded straight. Any ideas?
Is the right side door closed fully???
Posted on Oct 24, 2007
If the Image is straight and not skewed on the paper then the first suggestion is a good one. I would only add to try fresh paper if you have a finisher. Even a little humidity in the paper will catch as it exits.
If the Image is crooked on the paper: Try putting the some paper in the bypass tray and be sure that the paper guides are touching the paper. If the image is still crooked it is certainly in the machine. Then take a look at the leading edge of the paper and see if there is a "dent" on the very edge. This means that something is touching paper as it passes through the machine and is before the image area. If there is no sign that anything is touching paper it may a transfer charge problem though unlikely
if the image is straight when you use the bypass tray then it is most likely a problem with the paper. Take out the paper and fan it to release any static. Also check the tray guides and be sure they touch each edge of the sheet. Then reload the paper about 100 sheets at a time. I would not fill the tray I would just start with the first 100 sheets and test.
Posted on Oct 11, 2007
  • 163 Answers
Dear sir please check the upper heat roller claws set,may be one of them is bended up
Posted on Oct 01, 2007
SOURCE:
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
Pls tell me the life time of the developer powder and do I have to use only original toner
Hi, I have not come across any expiry date of toner/ developer and if it is stored properly in a cool dry place, away from sunlight an excessive heat, it works just fine. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare. Genuine toner is always better in terms quality and yield. However, refill can work too.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine. As for Panasonic Workio DP-4530 and similar copiers, the toner comes in a bottle (which is only a container filled with toner powder) and the toner powder is pulled by the toner supply unit of the copier. I am using HP 9065MFP and refilling caused no issues. I usually refill it after proper servicing and use best available powder and it works absolutely fine.
On DP-2330 my copies come out with lines and looks dirty
Hard to say without knowing how many copies it has done.
Suggest that it may need the mirrors/optics cleaned,may require a new drum,drum blade,fuser web,fuser roller ,developer or may even be non genuine toner.Suggest that a technician has a look at your copier..
Nov 18, 2010 | Panasonic Workio DP-3520 Copier
Crooked copies
Tighten the fences and guides that hold the paper in place. If the paper is not snug in the tray, it will not pull through straight.
May 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I have Panasonic Workio DP-2310 copier and there were multiple lines the length of the copy .I cleaned entire copy and drum area and installed new toner cartridge now the copies are coming out blank , no...
check you drum charge connection between drum unit and developer unit, two metal strips at back that contact when the two unit are closed. none or bad connection means no charge and then blank copies
Feb 01, 2010 | Panasonic Workio DP-2310 All-In-One Laser...
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Dp 4520 error code E03-60
error e03-60 means waste toner collection. could be a problem with the mechanism that delivers the toner to the waste bottle. looks arround there
Oct 09, 2008 | Panasonic Workio DP-4530 Copier
2nd side crooked
I would have to say that there must be a same piece of paper touching the paper as it is being feed through the duplex ass'y. The best thing to do is to see if the copy gets tilted toward the front or rear of the copy/ copier. You will be able to find where the obstruction is in the dupex path.
Feb 23, 2008 | Canon D320 imageCLASS Digital Copier
Req: Panasonic Workio DP-4530 service manual
In the service mode there might be an automatic fuser and drum cleaning mechanism that could be activated. The fuser web is in the drum section of the unit and when this is coated with toner and the cleaning mechanism is inactive, you could get this problem.
Let me know if you do not know how to get into the service mode of the copier. It normally is pressing the following three buttons simultaneously - Original, Function and the number 3. It may take a few tries before you get the sequence properly. Also, if it requests a password, try 0000 or 00000000 (8 zeros or 4 zeros)
Jan 06, 2008 | Panasonic Workio DP-4530 Copier
Panasonic Workio DP-4530 Copier Logo
440 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
