Question about Heat Controller Heating & Cooling
Heat pump won't start its a trane YCC024-SF-3b Model #YCC024F1L0B led indicates pressure switch problem what do i do to fix it?
  • Md Titoo
    Md Titoo Apr 26, 2015
    I had the same issue. I unhook the tube goes to pressure switch, blew it and hook it back. After turn on the heat and it started working. If not change the pressure switch SWT1858. Don't forget to shut off unit power before working on the system.
    Top Expert:
  • Heat Controller Master
  • 10,875 Answers
Replace the pressure switch
Posted on Apr 26, 2015
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: My Trane thermostat (TCONT600AF11MAA) is
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Posted on Jan 02, 2011
mc1bean
  • 3053 Answers
SOURCE: why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Posted on Oct 21, 2011
  • 613 Answers
SOURCE: Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Posted on Aug 30, 2013
Heat pump compressor/fan/air handler runs heat for 30 secs, then all stop. (Trane XR 11 HP w/honeywell T8411R thermostat). Capacitor good, new 5-2-1 hard-start kit added but didn't solve problem.
Sounds like low pressure. Are you losing low voltage to condenser? Backup heat not working likely due to a setting error or possibly a wiring issue.
Nov 14, 2016 | Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Goodman Gas Heating A/GPG13 Not Heating - Pressure Switch Stuck Open
Clear the little hole where that hose go to the inducer case
Feb 10, 2013 | Goodman Manufacturing Goodman...
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
Will not empty water
Hi.
If the machine does not drain you usually have drain blockage. Clean the drain well at the bottom of the tub. remove and clean filter and assembly parts. Make sure that the drain hose at the back of the dishwasher is not kinked.
Several Miele dishwasher uses a pressure switch to determine the water level. A defective pressure switch may prevent the machine from starting.
If this model uses a pressure switch, the switch will be located in the drain line. When a pressure switch is defective the machine should return an error code. Here a picture of the pressure switch:
If that does not fix the problem the pump located under the bottom panel must be tested.
Regards.
Ginko
Dec 15, 2011 | Miele 24 in. G2180Vi Built-in Dishwasher
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Trane XL19i 8? ton heat pump not heating very well
Your second stage heat check the dip switches on the board and the wires to the proper two stage heat t-stat.
Feb 06, 2009 | Omega Trane Furnace Draft Inducer Blower...
Heating & Cooling Logo
112 people viewed this question
Top Heat Controller Heating & Cooling Experts
jdthefixer
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you a Heat Controller Heating and Cooling Expert? Answer questions, earn points and help others
