Question about Cfm Klimaire KSWG009H113 Split System Air Conditioner
KSIB018-H216 says HC when I select cool mode and puts out heat
Ruud classic 90 furnace (LP) doesn't come on. Fan will run when thermostat set to on (heat & cool both off. Troubleshooting chart?
will you need to put either heat mode on or cool mode to on for any type of operation other than just fan on
Jan 14, 2017 | Ruud Heating & Cooling
I have 2 zones, both of which are programmed. The display for zone 2 works fine. When I am looking at zone 1, the desired heating and cooling temps display as -- with no temps there. The system is set on...
Are these reading temps at 2 separate tstats or are you using temp sensors that send the temp back to the stat. It sounds like the sensor is not communicating with the stat.
Jun 14, 2017 | Carrier 38CKC042 Air Conditioner
Gree air conditioner error codes HC
I have also use GRE ac inverter but today my ac on running sundunly show (HC )Main screen
Plz information this system
HC maens what's problem
Aug 19, 2013 | Heating & Cooling
The ac is not working properly. It goes from cold air, to hot air. I charged the ac with R134 coolant, but is not helping. What is the problem?
If your unit is cooling and heating ok make sure the mode your on is not an automatic mode as this makes the unit change between heating and cooling to maintain set temp select either cooling only mode or heating only mode this means once set temp is reached unit will stop until it notices a rise or drop in temp and will come on again in your set mode
Jul 03, 2011 | Heating & Cooling
1989 Toyota 22re fails California Emissions Test. Rebuilt the engine 20K or so miles ago. Has passed most tests with just a little bit of timing adjustments. At 15 MPH, (1670 RPM) HC measures 153...
HC is hydrocarbons or unburnt fuel.(raw fuel ).NO no such gas measurement.did you mean CO this is carbon monoxide or incomplete combustion.(all the fuel is not being burnt).if you mean NOX this is nitrates of oxide and is related to a heat problem.(motor running hot,bad catalytic converter).its probably getting too much fuel and not burning it all,possibly tune-up problem,carburetor(if it has one),bad fuel injection system(dirty injectors),computer(if it has one)may be getting a wrong signal.these are in reference of high HC and CO.for high NOX cooling system not keeping motor cool enough,cooling fan problem(weather clutch fan or electrically controlled cooling fan),poor cooling system circulation,bad catalytic converter.not a running lean problem as the other gases indicate rich problem.the converter may not be able to convert the emission gases to H2O and CO2 out the tailpipe.
Apr 24, 2011 | 1989 Toyota Pickup SR5
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
Conia CA1800 wont heat
there should be a mode button, press it until you see the sun sign
Jul 09, 2009 | Heating & Cooling
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Heated air coming out when unit is in Cool Mode
Heat pumps are sometime constructed to "Fail in the heat mode." It could be either the t'stat or the reversing valve. Be sure the t'stat is wired correctly. Usually the"O" terminal is for the reversing valve on the outdoor unit.
Mar 28, 2009 | Heating & Cooling
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Cfm Klimaire KSWG009H113 Split System Air Conditioner Logo
21 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
