Question about Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum
My Electrolux pronto 2in1 vacuum was not charged when plug into the charger
  • 21 Answers
SOURCE: Electrolux Pronto 2-in-1: Looking for a part
There is no replacement for the dust container in these units. You would have to get an entire handvac which costs more then a full unit.
Posted on Jul 19, 2009
SOURCE: My Electrolux Pronto is not charging. When I put
Call electrolux there was a battery recall
Posted on Apr 17, 2010
EwingElect
  • 276 Answers
SOURCE: Where can I obtain a free manual for the
If it's one that look like the one pictured, it's called another name in Australia, but the premise would be the same. Try
http://www.electrolux.com.au/Files/australia_english/Manuals/Cleaning_2007/ZB2812-ZB2813-ZB2815Instructions.pdf
Regards
Posted on May 25, 2010
SOURCE: My Electrolux pronto is slow to start, if it
I just wanted Electrolux to know that this is the Pronto 2-1 is the worst product I ever purchased. I thought after I received the new battery because of the recall it would work.
When I was going to purchase the stick broom I was going to get the Shark but because I knewElectrolux was a good name in products I decided to purchase the Electrolux which I truly regret because it was just a waste of money
Posted on Jun 04, 2010
  • 2418 Answers
SOURCE: I have a electrolux Pronto 2 in 1 and the suction
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
Posted on Jan 27, 2011
The blue light doesn't stay on. What do I do?
Hi Alec from VacuumSpot here. In Australia these are sold as the ergo rapido. The most likely culprit is the charger itself we sell loads of Electrolux Ergo Rapido Chargers basically the best bet is to measure the output of the charger to see if it is working properly (watch video) if it isnt then simply replace the charger. If it is then replace the vacuum handset - Electrolux have made the handsets real cheap so you dont have to do a repair on battery or motor.
Oct 26, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The blue lights on the charger base for the pronto stick vac go out after about 5 seconds and the vacuum is not working. What do I do?
check that the contacts are connecting and are clean of debris. If they are you can check the charging plug to confirm it is putting out 15v if not replace the charging plug. this is a common problem. you can get parts online at http://www.vacpartswarehouse.com/Electrolux-EL1000B-BZ-Pronto-Stick-Vac-s/3734.htm?gclid=CKDFg_3Jv7kCFc4-Mgody1wAjg
good luck
Oct 21, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
I have the Electrolux Pronto 2-in-1 Vacuum and need a new charger Where can I get one as soon as possible Thank you
This is a good URL for your part
http://www.ereplacementparts.com/electrolux-parts-c-109672.html?osCsid=ip7otskdiu58aaud0fgvvv1f57
Oct 12, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Lost charger
You have to call electrolux and order one their numbner 800-896 9756
Jan 18, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
