Question about Microwave Ovens
Kenmore 318279600 The microwave begins to spark and smells like smoke after 6 seconds of running.
MicrowaveSvc
  • 9047 Answers
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Posted on Apr 11, 2007
grandadfixer
  • 99 Answers
SOURCE: Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Posted on Oct 11, 2008
  • 4 Answers
SOURCE: where can I take my Emerson Microwave to be
Check the wires for the door switches make sure they are not touching. If they are pull them apart and put new ends on or just some electrical tape.
Posted on Mar 26, 2009
  • 686 Answers
SOURCE: kenmore over the stove microwave will not heat 1996
YOUR MAGNETRON IS MOST LIKELY BAD. THIS IS THE UNIT THAT CREATES THE MICROWAVES.
Posted on Apr 12, 2009
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
I put a mug of water in the microwave, left the room. Came back, and the room was filled with a burning electrical/plastic smell, no visible smoke. Now, the microwave completely powers off after 1 second...
Since there was no smoke, it's not a transformer. It's most likely a high voltage diode or magnetron. The magnetron would be over heating and opening a thermal cut out mounted to or near it.
Oct 19, 2013 | Samsung SMH9187ST Microwave Oven
Will the fuse in amicrowave cause the burnt smell
No! if the microwave still runs, mix water and vinegar in a cup, set timer for 60 seconds and run microwave oven until you see steam develop and turn off, this will bond to the interior walls and should solve the burnt smell problem, repeat if required.
May 19, 2012 | Kenmore Microwave Ovens
GE Profile Spacemaker Microwave Oven (JVM1660WB 005) - after a few secondss, it crackles and begins to smoke/smell?!?! No problems for years.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Apr 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
Feb 09, 2011 | Kenmore 62622 Microwave Oven
Microwave starts to work then cuts out after a problem I had.
MICROWAVE RUNS ABOUT 5 SECONDS AND SHUTS OFF AND SMOKE FROM UNDERNEATH CABINET
Apr 15, 2010 | Bosch HMT9626GB Microwave Oven
Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Apr 02, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Where can I take my Emerson Microwave to be repaired? Microwave begin to spark where light bulb is and smoke, leaving a burnt smell in the air.
Mar 21, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave smokes and smells like burning plastic
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Kenmore 62622 microwave
A component of the high voltage section has shorted, possibly the diode. If it was the capacitor, it would normally blow th fuse.
If it is the high voltage transformer and you continue running it,
it should devolpe smoke in about one minute. Either way, a part
will have to be replaced to correct the situation.
Mar 07, 2008 | Kenmore 62622 Microwave Oven
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
