Question about Dryers
Electrolux edc77550w drum makes a loud noise
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 11, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer making loud noise ...
The problem is with the guide wheels that hold the drum. If they allow the drum to move too much then the belt is loosened and then the drum will not turn.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 16, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: dryer drum making noise but
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 11, 2011
Electrolux model EIFLS60LSS.
Malfunctions that produce loud noise requires visual inspection. If is question about new appliances then make sure that you properly remove the screws that block the drum and special plastic holders on the housing through which the screws fixing the drum (described in user manual). If you didn't remove this holders they will produce loud noise and sometimes can destroyed door gasket.
In my country failures of the bearings are covered in the warranty period, except in the case of overloading, which is almost impossible to prove. Unfortunately, for your country I do not know, but I think this can be easily check by phone call to your nearest dealer.
Dado
Mar 09, 2017 | Electrolux Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
Front loader jumps over the floor and makes loud noise when on spin
Hey friend, thanks for your post!
It sounds like a possible issue within the drum of your Electrolux washer and that is why it is jumping around and making a noise. Is this a new installation? If so, I would suggest checking the back of your washer to assure the shipping bolts have been removed.
If it is not a new installation it could be a potential issue with your shocks or drum and I would suggest seeking additional assistance from a professional for further help. I hope this information is helpful. -Matt
Oct 02, 2014 | Electrolux Washing Machines
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
Dryer is making a noise that sounds like something is loose in the drum it is still drying very loud at first then gets quieter as it goes.
The dryer drum rides on a center bearing (plastic on metal mount). In time the plastic bearing disintegrates and the ball begins to rub the metal mount. If left like that after a while the ball will be cut in 2.
Another thing that goes south is the plastic slides that the drum rides on in front.
My Electrolux Dryer repair page
Mar 29, 2011 | Frigidaire Dryers
We have an electrolux EWF 1087 and the drum is rubbing on the rubber seal causing it to smoke and shudder and making a loud noise. Can you help?
You have a big problem . Sounds like the (spider) on the rear of the inner drum is broken. Means a new drum and rear tub plus about two hours labour to repair.
Feb 27, 2011 | Electrolux Washing Machines
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Dryers Logo
Top Dryers Experts
