Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
Djx 700 Assign not working and kill key - Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
2 Suggested Answers
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Im not getting anything from my djx700 master output, getting sound from booth output. what could this be
The first thing I would look at is the kill switches on each side, make sure these are not pressed. Also make sure the master fader is up. I would disconnect anything that may be plugged into the effects loop send and return. Make sure the main outs are plugged in correctly, the main master outs should go to a power amp, this unit appears to be a unpowered unit. Make sure you are using the proper cables to avoid damage, lookup and understand the difference in speaker cords and instrument cords and place them properly. Also make sure the "assign A" and "assign B" are positioned correctly. Hope this helps but, if you give me a little info on how you are using this unit, I could help you further, please.
Mar 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Jul 17, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I replaced the transformer and fuse which is in a sealed compartment above the power supply connection in djx 700 (behringer) and still have humming in the new transformer
Transformers rarely fail... you wasted money on that... Likely one of the rectifier diodes/module or filter caps has shorted. Continued use will burn out the transformer. It is humming because it is overloaded with failing components.
Jul 02, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hi my behrinher DJX 700 - damaged transformer i think, i bought the unit in canada and i used it with a voltage converter, worked just fine, recently my son pluged it in the uk socket and it bloone the...
Sounds expensive. How did the Canadian plug fit a UK socket? The fuse won't have blown fast enough to avoid all damage. Their coucld be an internal fuse - see instruction book. It won't be a home repair job it its not the internal fuse - sorry.
Feb 14, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
The external speakers attached to my m audio prokeys 88sx are no longer working. I have replaced the fuses in both but the fuses blow on power up. I then used the keyboard with a set of headphones. One of...
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
Jan 16, 2011 | M-Audio Pro Keys 88 Premium Piano
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I plugged my djx 700 into a club system, within minutes it was boiling hot, it did not stop working but i only used it for 30 minutes, i'm using it for 7 hours on friday night in the ame club, will it stop...
Suspect a ground problem someplace in the system.
Make sure your system is plugged into exact same recepacle that anything else you connect to is plugged into.
Also make sure a spot light is not heating it.
Oct 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
41 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
