Question about Kenmore Sewing Machines
Need manual for kenmore sewing machine model # 385.12314990
SOURCE: kenmore Sewing Machine
www.mastersewusa.com has free kenmore manuals
Posted on Feb 17, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Posted on Apr 02, 2009
Manual for kenmore sewing machine model 158.18032
Type manual for Kenmore sewing machine model 158.18032 in your search engine on your computer, it will take you to where you need to go.
Jul 11, 2017 | Kenmore Sewing Machines
I NEED THE OWNER MANUAL FOR MODEL # 15818034.
Sears Parts Direct has a portion of the Service manual for the Kenmore 15818034 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-Machine-Parts/user-manuals/manual-downloads/Model-15818034/0582/1200000?modelNumber=15818034&diagramPageId=&documentId= . However, the owner's manual for the Kenmore 158.1803 should help you since it is from the same line of sewing machines. This manual is available from SewUsa here: http://www.sewusa.com/Sewing_Machine_Manuals/Kenmore_Manuals/1803_Instruction_Manual.htm . It's also available from Sewing Parts Online here: http://www.sewingpartsonline.com/instruction-manual-kenmore-158-18030.aspx .
I hope this helps.
Feb 03, 2016 | Kenmore Sewing Machines
Where can I buy a manual for my Kenmore sewing machine?
"need make and model of the sewing machine in order to help you."
Nov 07, 2015 | Kenmore Sewing Machines
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
Aug 15, 2008 | Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
