Question about GPS
Libyamax xxxx - GPS
I am using the libyamax internet and i did install the device but still not conected
When you set up your route, did you make sure that DHCP was enabled? And on the computer, right click on your network adapter and go to properties, make sure that it is set to obtain an IP address automatically.
Jan 18, 2011 | Computers & Internet
After installing office 2007 it is asking product key??? i dnt know what is product key. Plz help
Product key comes with the software. It is the product license.
it's a long series of numbers, like xxxx-xxxx-xxxx-xxxx-xxxx.
Aug 15, 2010 | Computers & Internet
I need serial number of sony sound forge 9.0 wich stars wid 15H-XXXX-XXXX-XXXX urgently please help
i need serial number of sony sound forge 9.0 wich stars wid 15H-XXXX-XXXX-XXXX urgently please help
Jul 05, 2010 | Sony Sound Forge 8.0 for PC
Sound forge pro 10.0 serial number it will look like 164-XXXX-XXXX-XXXX
Try these Serial Keys:
they are working:
164-S3PL-LB9Z-1X3B
164-J0PB-PJVB-L2R3
Apr 07, 2010 | Sony Computers & Internet
Canon fs 10 serial number for image mixer
There is a sticker on the battery cover, with a the serial number. It's listed as four numbers, in three rows...
xxxx
xxxx
xxxx
Enter into the software as xxxx xxxx xxxx -- worked for me.
Jan 26, 2010 | Canon FS100 Flash Media Camcorder
I lose registration
From the run command in windows
click Start
Select Run from the menu
The Run window opens.
Enter "regedit" in the text field and click the OK.
The Registry Editor opens.
the serial number is on the left side in the navigation area.
Follow the path
HKEY_LOCAL_MACHINE\SOFTWARE\Nport\Installation\***\***\Info
the serial number is next to the "Serial*" entry. Looks like this:
1K2x-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx or
2K2x-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx
*** text may vary
Nov 28, 2009 | Xitel INport Deluxe
Show the serial number of nero 8
If you have a PC: Go to Start, then Run. The run window opens. Type regedit into the text field and click ok. The registry editor opens. Look to the left.
HKEY_LOCAL_MACHINE\SOFTWARE\Nero\Installation\Families\Nero 8\Info
• Your serial number is displayed next to the "Serial8" entry. It is structured as follows:
Write down your serial number
If your copy is registered with Nero, you can go
login to the Nero website to get your SN:
https://register.nero.com/eng/login.asp
Nov 17, 2009 | Ahead Software 8 Ultra Windows
How do you setup the IP address on a toshiba tec b sx4t printer?
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions
{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
Sep 30, 2009 | Toshiba TEC B SX4T Printer
When i try to play a and b speakers it says low impedence ??????
I just saw in the title that you're getting a Low Impedance indicator on the receiver...
Following what I said earlier, when you have multiple sets of speakers selected they connect in parallel, effectively presenting a lower impedance than either pair does alone. If your receiver is warning you of Low Impedance you could
A) Ignore it if it doesn't have any audible effects; or
B) Avoid the issue by not running the speakers together or
C) If you must have them running together, wire them in series with each other to present a higher load to the amp and connect each pair of series speakers to the A or B terminals. It would look like this...
spkr A spkr B
XXXX XXXX
L ++++++++XXXX++++++++XXXX
L --------------- XXXX--------------- XXXX
XXXX XXXX
XXXX XXXX
R ++++++++XXXX++++++++XXXX
R --------------- XXXX--------------- XXXX
XXXX XXXX
Apr 02, 2009 | Technics SA-DX950 Receiver
GPS Logo
1,986 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
