Question about Acer Aspire One Netbook 8.9" Notebook
I have an acer chromebook. i bought it two months ago and now it turns itself off when ever im watching videos. i got a cooling dock and its still doing it. any suggestions?
    Problem Solver:
  • 13 Answers
Get it fixed under warranty from Acer - seriously. It is not worth messing with if it is under warranty. Save your data on a flash drive or external hard drive prior to calling. Here is their primary contact phone number - just ask for technical support: (408) 533-7700
Posted on Oct 21, 2013
3 Suggested Answers
gowtam1402
  • 89 Answers
SOURCE: Hi! I Just bought a
This is a Operating system issue. If this is a Windows 7 OS there is something called bit-locker which is used for encryption purpose. At times this creates a problem.
Hence if you have a recovery disk with you, you can rebuild or re image the PC.
This should fix the issue for you.
Thank you
Gowtam R
Posted on Jan 20, 2011
joecoolvette
  • 5660 Answers
SOURCE: my acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Mar 05, 2013
Bought a chromebook acer 14 but it will not turn on after fully charged
hi Diane.
How To Fix Your Chromebook If It Won't Turn On More users are reporting that their Chromebooks are not turning on or the screen stays black. For some the problem comes and goes but for others their machine just stays off all the time. If your Chromebook doesn't turn on there is a few different problems that can be the cause.
This article will go through all the possible causes. I've arranged them in order from simplest to fix to most complex so that you can go through them one by one until your Chromebook turns on again.
So just try each fix and stop when your Chromebook turns on! Cheers!
Fix #1: Connect Your Chromebook To Power Let's start with a very simple solution that worked for one of my customers at my computer shop. Simply take your Chromebook, plug it into the wall power outlet, and try to turn it on.
If that doesn't work no worries move onto Fix #2.
Fix #2: Power-Cycle Your Chromebook
  1. Unplug your Chromebook from power.
  2. Remove the battery is that is possible on your model of Chromebook (it isn't on most Chromebooks)
  3. Press and Hold the power button for one whole minute.
Now try to turn on your Chromebook.
Fix #3: EC Reset Your Chromebook Fix #4: Let Your Chromebook Charge For A Few Hours If the Chromebook is very low on charge it may just need to charge. Let it sit plugged in and charging for around four hours. I suggest leaving it plugged in over night.
Try turning it on in the morning.
Fix #5: Disconnect Battery And Power-Cycle (Advanced) Most Chromebook machines have a built in battery that is sealed inside. However most of the batteries are not that difficult to reach if you have a screwdriver and are careful.
Look up a disassembly video for your chromebook model on youtube and watch it to see where the battery is located.
  1. Unplug your chromebook.
  2. Open your chromebook to get to the battery.
  3. Disconnect the battery cable.
  4. Carefully move the chromebook so that you can reach the power button. Press and Hold the power button for one minute.
  5. Re-connect the battery cable. Make sure the connection is secure.
  6. Close up your chromebook. Plug it in.
Try turning it on now.
or try this link out might help you some more.
chromebook acer 14 but it will not turn on Google Search
Dec 03, 2017 | Acer Computers & Internet
What is the simplest way to transfer pictures and videos from my I-Phone 4S to my Chromebook ??
Join Google drive
Install Google drive on iPhone
Upload/download as required but make sure your using wifi
Jan 03, 2015 | Cell Phones
Pitcure and usb problem
usb is shorting out the 5 volts. as its only 2 months old would take it back to the place you bought it and get a replacement.
Mar 02, 2018 | Philips 27PT81S 27" TV
Acer chromebook c7 wont charge
You may need to replace the battery, especially if you have had your Chromebook for awhile.
Nov 07, 2013 | Acer C710-2487 4096MB 11.6" Chromebook
My acer keeps on randomly capitalizing random keys im not pressing shift, i checked
Hello i think your keyboard is corrupted and it must be changed.
A computer repair shop can help you renew the keyboard.
It does not cost much.
Good luck
Dec 28, 2012 | Acer Computer AC700-1090 Chromebook
Man i paid 600 bucks
6 months old is still under warranty. You should not attempt to fix an item that is still under warranty, instead contact the shop you bought it.
Oct 22, 2008 | Sony PlayStation® 3 (60 GB) Console
Portable DVD player- screen problem
cheap product and cheap material, have you tried another video??
most players dont last more then a few month of hard core playing like every day for 4 hours since youve bought it.
im sure its burned out. laser eyes can go bad or even the invertor since there is no real way the dvd player can be cooled.
so im sure its burned itself out
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Aug 11, 2008 | GPX PDL805 Portable DVD Player
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Acer Aspire One Netbook 8.9" Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
