Question about Philips DVP5140/37 DVD Player
Philips 5140 will not eject - Philips DVP5140/37 DVD Player
How do i eject a CD/DVD wit the Philips SRP3004/10? It doesn't have a button with the eject icon on it...
some do not have eject option ,only way is to doit at the device since they do not auto load or replace disk U need to be there .
Jan 18, 2015 | Philips SRP3004/10 universal remote...
Looking for the program code for the Philips dvd player DVP 5140
The code will be different depending on which remote control you're using. What type of remote control do you have?
Jul 18, 2011 | Audio Players & Recorders
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
What video format does this dvd player support.if i write a dvd it is not working in this player
Philips DVP3020 does not support popular vidoe formats such as DivX / xvid / mp4. so if you download movies from the internet and burn to a DVD, chances are it will not work. this philips player is very basic and can only play regular DVDs, VCDs and audio CDs. that is why it is cheap. you should try Philips DVP 3010 or 5140, even better the 5960.
Oct 02, 2010 | Philips DVP3020 DVD Player
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
I was watching a dvd and it froze half way as i was watching it. it now says blocked and wont eject the dvd any help would be great thanks
1. You will need the Philips support to eject this DVD
call the tech support and they should give you the remote code to eject the DVD.
Feb 04, 2010 | Philips DVDR610 DVD Recorder
Philips DVP3962 dvd player not showing picture when play dvd but can hear music. Sound is going through receiver and video hooked up to go through tv.
I put A dvd in my phillips dvd player dvp 5140 player and it say put in a password i never put a password in it how can i get rid of it
Dec 28, 2009 | Philips DVP3962 DVD Player
My dvp 5140 wont support certain codecs. can i up grade them?
yes and no.yes, but you need to bring it to its service center. no, you can't do it yourself.
May 07, 2009 | Philips Televison & Video
Philips dvd 3445h doesn't seem to support pal format
You would have to either convert the DVDs to NTSC by ripping them to your computer and using conversion software, or you need to get a player that supports PAL and NTSC. Phillips has players that do both NTSC and PAL but it sounds like the one you have doesn't.
I have a Phillips DVP 5140 that does PAL and NTSC and is region unlocked.
There are other players on the market that do support it, but you will have to look around a bit.
Best of luck
Jan 04, 2009 | Philips Televison & Video
Philips DVP5140/37 DVD Player Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
