Question about Hoover AAA140 Front Load Washer
Programme Lock How on earth do you switch the Programme Lock off on a Hoover AAA140 washing machine?! The keypad is currently locked and I can not unlock it! Many Thanks Matt
  • Keysey Sep 28, 2007
    I have finally got it to work by holding down the programme lock button until it flashes, then pressing the fast iron button. However, after 10 seconds the programme lock automatically kicks in again.
    Thanks for your help.
    Matt
  • relaxcord Dec 24, 2008
    I am trying to start the washing machine but the door security light is on permanantly when it should flash. The door has been repaired and tested and works. When returned by the repairman the problem is the same and I cannot get it to work. Is there a way to unlock the progtamme or does the memory need resetting?
  • 725 Answers
Did you try to hold the button in for 5 to 10 seconds let me know if this worked?
Posted on Sep 28, 2007
SOURCE:
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
Cannot open door and lock light stays on
It has a timer circuit that locks the door with a selenoid. It has a sprig that pulls the safety latch back off of the latch. Either it isn't turning the power off or the spring is broken or too dirty with soap and wont work right. Try pulling the power and see if that works. If not got to take front cover off and check it out.
Jun 01, 2010 | Hoover AAA140 Front Load Washer
I cannot open the door after the finish of the
Hi There
I have found this for you to read.let me how it goes. Hope this was helpful.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Washing Machines
How do you repace the door hing on a AAA140 Hoover
should not need to as the 2 screws holding the hinge to the frontplate of the machine goes into a threaded nut welded to the panel (a torx 30 or 40 bit is needed).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Dec 18, 2009 | Hoover Washing Machines
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Why wont my washer start?
Keypad is locked out. look in user guide under control lock and unlock the keypad
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Motor wont spin
whats makes the noise on spin if motor not turning at all.. i kinda confused... I Would check lid switch and see if maybe that might be the problem.. havnt had a lot of experince with hover but most washers have lid switchs to prevent spinning when lida opened
Sep 02, 2007 | Hoover AAA140 Front Load Washer
Hoover AAA140 Front Load Washer Logo
173 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
