Question about IBM ThinkPad R32 2658 Notebook
Keyboard error stuck key 69 - IBM ThinkPad R32 2658 Notebook
Lenovo R400 Error 0210 stuck key 5b
Stuck key error means that one or more keys on the keyboard are stuck. It's possible that a liquid spill can also cause one or more keys to electrically "short" causing the error. Inspect the keyboard and check if any keys are mechanically stuck.
If you're mechanically handy you can remove the keyboard, inspect any chances of damage or corrosion. Plug it back and see if error is still occurring.
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
Aug 19, 2016 | Lenovo ThinkPad R400 Notebook
Got ERROR CODE-2C00:021D
Anonymous,
The Error code that you have mentioned, 2C00:x21D, indicates that a 'Stuck Key' has been detected. The keyboard is continuously transmitting a scan code. The touchpad error might have come up because of the stuck key. You may have to replace the keyboard.
Thank You,
Dell-Jesse L
DellCares
Dell Social Media and Communities
Jul 20, 2014 | Dell Studio 1737 Laptop
Error 210 Stuck key 69
Hello Scott,
Make sure that there are no objects placed on the keyboard, or
if you have one, the external keyboard. Turn off the computer,
and turn off all attached devices. Turn on the computer first;
then turn on the attached devices.
If an external keyboard is connected, do the following:
v Turn off the computer and disconnect the external keyboard;
then turn on the computer. Make sure that the built-in
keyboard operates correctly. If it does, have the external
keyboard serviced.
Make sure that the external keyboard is connected to the
correct connector.
Please feel free to ask me if you any further questions or concerns.
Also please rate me if you like my answer, that helps me alot.
Thanks.
Apr 19, 2012 | Lenovo ThinkPad R400 Notebook
My IBM think pad has an error message of "stuck key 01" pls. help laurabaylon@rogers.com
If you've got a spare keyboard lying around give it a try and see if you get the same error message.
This means one or more of the keys on the keyboard is stuck down.
Look at the keys to see if one or more of the keys is lower than the others. If the key cannot be released or fixed then the keyboard needs to be replaced.
This problem can be caused by spill liquids on the keyboard.
If that doesn't work try resetting your BIOS back to its default settings.
Jan 15, 2011 | IBM ThinkPad Z60m Notebook
My laptop Acer asphire displays the symptoms of a stuck key error, but when I removed the key board the same problem occurs. the nuber 5 key still stuck.... but there is no keyboard installed anymore.
Since I see that you are comfortable with your computer I would like to recommend trying two different things. First off try using an external keyboard. See if this stops the error. If that does not then take the computer apart and remove the CMOS battery from the motherboard.
Jun 04, 2010 | Acer NSK8458AN Keyboard
Error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
May 04, 2010 | IBM ThinkPad 390X 2626 Notebook
Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Oct 17, 2009 | Lenovo ThinkPad R61i Laptop
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Ff 301 keyboard error
1. This can happen if you have the mouse and keyboard plugged in the wrong ports. Can you double-check you are plugging the keyboard into the correct port.....
2. several keys pressed simultaneously
3. key on the keyboard is stuck (try a different keyboard and see if you get the same error.
Jul 23, 2008 | Computers & Internet
'stuck key' on IBM ThinkPad 390E (2626-DOU)
goto the device manager and uninstall the keyboard and restart the system. check that the error is still coming..
If still the error remain same ...shutdown the system and power off and just clap the each and every key of the keyboard to release the keys if any stuck. Check that error by rebooting the system. Hope that the problem is solved.
If still not then maybe the keyboard is going bad.
Cheers - Parveen
Feb 10, 2008 | IBM ThinkPad 390X 2626 Notebook
IBM ThinkPad R32 2658 Notebook Logo
23 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
