Question about Samsung HMX-F90 HD Digital Video Camcorder White
Turn off Mic
I want to turn of the mic as i do not want sound on my films
2 Suggested Answers
ddkandjak
  • 10 Answers
SOURCE: how to use mic on samsung digital home cinema system
Knowing a model number would help a small way. But, the general answer is, home entertainment systems with cinema device. The microphone jack is for calibration of speaker balance.
Posted on Jun 23, 2012
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
Jun 23, 2013 | Turtle Beach Ear Force X42 Headset
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
My radio quells back when my mic gain is turn up more than about quater way
sounds like a faulty "MIC" or bad knob inside radio. Your radio may have too much gain. Try using a ordinary straight "MIC" . Some radios are tuned to operate with a straight mic. If you use a "Power Mic" it may be too much gain and cause a squeal. Impedance of the mic must be matched. If its a 500 ohm use only 500 ohm. If its an 1000 ohm use only 1000 ohm "Mics". A straight factory Cobra mic(Coffin mic) has gave me the best performance I have ever used on a Cb radio. I can talk 50 miles on straight mics.
Apr 21, 2011 | Galaxy Radios DX 77HML Base CB Radio
I have a dell inspiron e1705. i have no sound coming out now. i installed a creative cam and since then i had to plug in the mic for sound to come out. now even with the mic installed there still isnt any...
Check your sound setting - volume out - if mic on turn it off - (gets turned on for testing).
Go to sound settings in Control Panel and check sound card setting for correct sound card output.
ALSO - check that MIC is plugged into MIC and NOT Speaker Out - common error.
Oct 18, 2009 | Dell Inspiron E1705 Notebook
I have been filming wildlife in my garden with a webcam through a 5mt  ext lead. The video works fine,but how can I get live sound from the webcam mic to play live sound through my PC speakers ?
Audio set up Vista
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Aug 16, 2009 | Microsoft LifeCam VX-3000 Web Camera
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Sep 16, 2008 | Canon HV20 HDV Digital Camcorder
Having trouble with the mic
Go to the mixer controls. Press the advanced button under the mic mixer control and turn off the mic boost. If the advanced button isn't on, go to control panel, select sound, and make sure that enable advanced features is turned on for both your sound card and your microphone device.
Aug 14, 2008 | Aiptek Pocket DV 5900 DV Digital Camcorder
Sound
1)double click on the speaker icon and see if it is muted.
2)Try another mic to see if it is the mic
3) go to control panel>system>hardware>device manager>sound device and make sure there are no X's or !'s on any component of your sound card if there is read what the problem is or reinsstall the driver.
May 28, 2008 | Asrock 775VM800 Motherboard
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Samsung HMX-F90 HD Digital Video Camcorder White Logo
83 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
