Question about Dirt Devil Easy Lite Quick Vacuum
Dirt devil not sucking air - Dirt Devil Easy Lite Quick Vacuum
  • 18 Answers
SOURCE: My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Posted on Apr 02, 2007
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
galati2k
  • 281 Answers
SOURCE: Dirt Devil Vision bagless not working
make sure your brush roller is turning.unplug the vacuum and see if you can turn the brush roller by hand.if it turns real freely then your belt is more than likely broke
Posted on Apr 09, 2009
SOURCE: our dirt devil vacuum is blowing out air instead
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
Posted on Jan 29, 2010
  • 694 Answers
SOURCE: my dirt devil is not
Check the hose to make sure it's not clogged. You can do this by dropping a marble in one end and allowing it to roll through. If clogged, try placing the "wrong" end against the intake port of the vacuum and turning it on. If this doesn't work, try a shop or canister vacuum, hooking up to the exhaust port. If still no success, you may need to take it in to the dealer.
Also check inside the intake port for clogs. The piece of flex tube in the power head is another area where clogs form easily.
Make sure the "dirt tank" is empty and the filter is clean.
Another cause of lost or poor suction/air flow is a leaky hose. For this, replacement is the only solution.
Posted on Aug 29, 2010
My dirt devil wont turn on
first thing to do is to look in the dirt container for what masy have been sucked up.
Nov 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil bagless upright. sucks up dirt in the front and spits it out in the back. I have taken it apart to check for visible clogs in hoses and checked belt and rollers all of which are fine. what next?
There seems to be no vacuum drawing the debris away from the brush head. Remove the debris canister to check for air blowing into it. Check particularly, the area where the brush head pivots off of the upright portion. Hope this helps!
Jul 26, 2010 | Dirt Devil M110000 Bagless Upright...
My dirt devil is not sucking,i cleaned out hoses and bottom seems to be turning fine?
The fan motor is probably not working. Does it sound normal? Higher or lower pitch sound?
Dec 05, 2009 | Dirt Devil Vacuums
Our dirt devil vacuum is blowing out air instead of pulling in air.
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
No Suction
it is probably the dirt fan. u may have to get it serviced
Jul 09, 2009 | Dirt Devil Featherlite Bagged VacuumVacuum
Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Mar 08, 2008 | Dirt Devil Breeze Canister M082550 Bagless...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Dirt Devil Easy Lite Quick Vacuum Logo
14 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
