My Hisense LED LCD TV model 40K366W picture is distorted. Not a signal issue. Signal is fine on other TV's in house. Appears as if the blue and green signals are not in sync. Imagine is bouncing vertically, with one color fixed or stable and the other is bouncing, about 4 inches below the fixed color.
2 Suggested Answers
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
How do i back up my pictures and software on my tablet because its stuck on the boot screen
If it has been struck at boot screen, you can't. Contact any technician. Probably it might not be impossible. Electro help
Nov 27, 2014 | Hisense 40K366W 40" 1080p Wi-Fi LED TV...
How can I connect my hisense tv to wifi? it wont show my wifi name in security mode. when I scan it says no ap?
Either your router is not set up to broadcast the SSID(network name),the router is too far away from the TV, or there is a problem with the wireless on the TV.
If you can see the SSID from the same location with your phone/tablet/etc then it is probably an issue with the TV. You can also check for a firmware update for both the TV and the router.
Nov 16, 2014 | Hisense 40K366W 40" 1080p Wi-Fi LED TV...
Blue Screen appears
A solid blue screen usually means no signal (set not seeing signal) look to see if same on all inputs. If you have a picture but the screen is blue that is a different issue.
Answer is based on model number listed here, let me know
as much as possible.
Dec 16, 2012 | Hitachi 50C10 LCD TV
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
