Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Looking for part for 20 + whispertone model # 116.3285590 C. Snaps on wand are broken and power nozzle won't run?
2 Suggested Answers
SOURCE: My Kenmore 116.25812508 power nozzle motor will
I have had this vacuum for about 3 yrs and nothing but issues with it. It's been in the shop already once and it needs to go again. No power in the power head. A wheel came off of the powerhead too .. keep snapping it back on but it always comes off.
I am disgusted with this vacuum
Posted on Jul 31, 2010
I have a Electrolux Guardian Encore E and the power head quit working. It has suction power head off and all other attachments work.
Try this. Remove the power nozzle from the lower wands. Remove the wands from the hose handle. Snap the power nozzle directly to the hose. Make sure all switches are turned on and try it. If the power nozzle now works, there's an issue with one or both of the wands. If the power head does NOT work, you've secluded the problem to the power head. With that being said and although it could be a power nozzle switch or a wire that disconnected inside, it's most likely the power nozzle Elbow assembly wiring that's worn out. This has been an issue with this model after so many years and you simply need to replace the Elbow assembly.
I hope this helps and let me know if I can be of any more help.
amerivac4u@yahoo.com. Hope this helped. :-)
Apr 02, 2015 | Electrolux Vacuums
The power head of my 1165581590C Kenmore Power mate Whispertone 12 amp vacuum won't open. It is an older model and it desparately needs a clean!
I am not 100% sure of the model number but most of their powerheads come apart quite easily if you know how. There is a light lens cover on the top of your powerhead. On each side of this cover there is a little clip that holds it in place. You can usually see that spot by simply taking your thumb and pushing the light cover to one side or the other. Place a small flat head screwdriver in that slot and gently pry upward.
Once that cover is off, you will see two screws. Remove those two screws. Now simply grab each side of the cover towards the bottom and back of the nozzle and pull out. This should release it from the base. It will lift from forward from back to front..
Reassembly is pretty easy. Just reverse the instructions.
Let me know if this helps.
Dec 30, 2012 | Vacuums
The power nozzle on my c141b model aerus electrolux canister vaccum no longer turns on. It was working when a large stringy object was sucked in. When hitting the red reset button, nothing happens. Is...
It's not a fuse.
Turn the power nozzle on it's top. Try to rotate the brush. If it won't spin, there's till something holding it. Remove all strings, threads, and whatnot from the roller. Try to rotate it again. If it still won't spin, it needs to be taken to an authorized Aerus Electrolux store for diagnosis and/or repair.
Try connecting the hose directly to the power nozzle to see if runs. If it does there's most likely a broken or disconnected wire/cord somewhere in the wands, or the power nozzle. If it doesn't, the problem is with the power nozzle. It could be the motor, although that's unlikely. Other possibilities are broken or disconnected wires or a bad switch. Again, it needs to be taken to the shop to be diagnosed.
Disconnect cord to the power nozzle and examine the prongs on the cord and the terminals in the power nozzle. If there's any discoloring or cracks, they need replaced. Reinsert plug and make sure it fits tightly.
Disconnect cord from wand plug and check for the same things.
Jan 24, 2011 | Vacuums
We have an electrolux central vac. The power head won't turn on. It has a 3 way switch on the handle. When to the left it is just air for the floor. center is off and to the right is the power head. ...
I assume you did press the reset switch on the power nozzle. If so, there are a number of things that could cause this. To rule out the hose and power switch, connect the Sidekick (if you have one) to the handle. Turn vacuum on. If the sidekick runs, the problem will be in the wands or power nozzle. Try connecting the power nozzle directly to the hose. If it runs, the problem is the wiring connections in the wands, or from the lower wand to the power nozzle. Check all connections for discoloring and broken or cracked wand fittings.
The wiring in the elbow of the PN is a fairly common problem, especially with certain models. A piece inside breaks, resulting in the wire connection to not make contact. No contact means the PN motor won't run. And there's always the possibility that the PN motor is bad.
If the Sidekick doesn't run when connected directly to the hose, the switch could be bad, the wiring in the hose could have broken, which is another common problem in older hoses, or the ECV board in the vacuum could be bad.
If the problem hasn't been resolved at this point, it's best to take the entire machine to the Aerus Electrolux store near you for a free diagnosis.
http://www.aerushome.com/storelocator/
Jan 07, 2011 | Electrolux Central Vacuum
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
Carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
GoVacuum.com
May 13, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The brushes are not rotating
Well, there are a couple of things to look at.
1. With the cleaner running, and the hose switch turned to carpets (2nd position) press in the reset button and see if that re-engages the belt. No?
2. You might have a broken belt. When you tried #1, did the motor on the power nozzle run, was the light on? If your answer is yes, and your roller is not turning, then your belt is broken.
3. If these are not the problem, then you could have either a bad motor in the power nozzle, or a hose switch problem. Well, I hope that this helped any. If so, please let me know. Thanks.. Rene (the Vacuum Doctor)
Nov 18, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Nov 10, 2009 | Kenmore Vacuums
No spinning in the power head
First, check the red reset button on the power nozzle head. - if it's popped out, push it in. Also, if you have a switch on the handle, make sure you're pressing it while you're vacuuming. if those obvious solutions are already remedied, you may need to check the power outlet on the canister for voltage with a voltmeter while the vacuum is running, and then check your power hose and wand for continuity (checking for a broken wire) while the hose is disconnected from the canister. If all this checks out and the power nozzle still doesn't power on, you may have a bad motor in the power nozzle. If you're good at taking things apart, then it's a simple fix to replace the power nozzle motor.
Jul 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
41 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
