Sanyo RM-6320 How do you set the time
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
Jan 30, 2015 | Sanyo Audio Players & Recorders
Chunghop rm-88e code for tv sanyo
Chunghop
...TV codes; 026 033 043 159 160 170 175 212 215 702 703 716. chunghop rm 109e code ...
Nov 26, 2012 | Sanyo Televison & Video
How to tune universal remote rm-300f+ to my tv
How to do an auto search for a Livewire Rm-300f+ Universal Tv Remote. These cheap (£1.00) remotes are available from poundland, etc.
1) Turn on your TV, ensure it it tuned to a channel and the sound is on.
2) Press the [set] button for about 5 seconds, until the LED stays on.
3) Press the MUTE button, the LED should flash twice.
4) Point towards the TV and press the power button. Don't worry if nothing happens.
5) Press and release the power button every second or so, eventually (for me about 120 times) the sound will go off. NOW press the [set] button to confirm your setting.
6) Pressing the power button again should switch the TV off. If not you're going to need to go through it all again.
Mar 18, 2010 | Sanyo AVM-3259S TV
Need to program the rm-v302 remote to a sanyo dvd/vcr player
Most of the combo units are hit and miss on using entry level remotes, Learning remotes or high end remotes are you two best bets.
You can try these Sony Remote Sanyo VCR codes:046, 044, 035, 033, 038
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
Mar 15, 2010 | Sony RM-V302 Remote Control
Codes for sanyo tv
codigos: 008,000,007,014,015,033,035,053,056,079,105,132,133,134,202,223
Jan 08, 2009 | Universal Remote Control Remote Control
21 people viewed this question
 Grubhead
Grubhead
