Question about Directv D11 Digital Satellite Receiver
Global Series GSR5298
Remote Control Unit is not working properly
Why remote not working in my 42 inch e series tv
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
If remote control is working properly, the infrared sensor inside the TV is faulty. If so, contact any service technician to replace it.
Aug 27, 2014 | Televison & Video
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
My remote for a Bose Wave Radio does not work any more. It just stopped one day. I replaced the battery and have made sure that the battery is properly installed (positive side up). I have unplugged and...
Aug 19, 2017 | Bose Additional Wave radio II remote...
Ceiling fan does not turn off using remote control unit. Problem just began this week.
Chek that your remote control is properly working or the batteries are down. If remote is all right then chek for faults in the fan.
Aug 08, 2009 | Dryers
SANYO REMOTE COTROL
1.check remote its working properly or not.
2.check temperature control switch.
3.put the temperature put below 16 n on the unit
4.if not working change the remote
Mar 27, 2008 | Heating & Cooling
My remote control stopped working
i do apologize for the inconvenience the only thing that i can suggest is the that whole unit will need to be reset. so the machine can connect again with the remote. also make sure that batteries are fully charged. If that doesn't work please let me know.
Oct 19, 2007 | Bionaire BAP1500-U Air Purifier
Directv D11 Digital Satellite Receiver Logo
73 people viewed this question
Top Directv Home Security Experts
Lawrence Oravetz
Are you a Directv Home Security Expert? Answer questions, earn points and help others
