Question about Sanyo AVM-2506 TV
Sanyo avm 2506 tv no sound
The only problem is that the tv set doesn´t sound on normal channels. It only makes noise when there is no signal (without an antenna). Thank´s for your help.
  • vickgv Oct 03, 2007
    I solved the problem only by adjusting the core of T131 (I think it's an audio filter, I don't know if it is the IF section). The coil of this T131 is conected to pin 4 of IC 101 LA7673.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Posted on Sep 28, 2007
SOURCE:
Where do i plug in my dvd player to a sanyo avm 2506
Get RCA cables they come in 2 or 3 conductors, Yellow andWhite for Mono and Yellow, White and Red for stereo connection.Connect the one side of the Yellow cable to where it saysVideo OUT on the DVD.
Connect the other side of the Yellow cable to where it saysVideo IN on the TV.
Connect the one side of the White cable to where it saysAudio OUT L on the DVD.
Connect the one side of the White cable to where it saysAudio IN L on the TV.
(optional) Connect the one side of the Red cable to where itsays Audio OUT R on the DVD.
(optional) Connect the one side of the Red cable to where itsays Audio IN R on the TV.www.aaatvservice.com
Jan 26, 2012 | Sanyo AVM-2506 TV
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Mar 06, 2009 | Sanyo AVM-2506 TV
Havin problem utilizing multiple inputs into Sanyo TV (avg-3259g)
if your tv has no AV IN AND OUT connections, purchase a converter from eletronic shops just around your area.
this will make you convert AV into RF signal and feed that to your tv. you have to go on a channel and search for right frequency the will search for you.
Dec 31, 2008 | Sanyo DS13204 TV
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
Hibhh
That doesn't mean anything
Apr 27, 2007 | Sanyo AVM-2506 TV
TV sounds like power up for few seconds then goes off
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
Mar 04, 2007 | Sanyo AVM-2506 TV
Channels change without changing channels!
check the tv system control the ic is probably bad have a tech check tv and make the repairs good luck.
Dec 21, 2006 | Sanyo AVM-2759S 27" TV
Televison & Video Logo
133 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
