Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
Schlage p513 649
Replacement parts?
Exploded view of parts for fe595 schlage digital lock
If you haven't already found this out, parts are not available.
Response from Schlage:
Thank you for your e-mail. Unfortunately if he had these locks on his business there is nothing we can do as far as repair. And unfortunately there are no dealers who have the parts available for repair. These are strictly residential keypads. I am sorry about this.
Joshua Bozarth
Consumer Loyalty Representative
Schlage Customer Commitment Center
2119 East Kansas City Road - Olathe, KS 66061
Mar 12, 2014 | Schlage Electronic Lock FE595 Plymouth or...
Keypads on Schlage locks
Answer from Schlage.
Joshua Bozarth
Feb 13, 2014 | Schlage Locks & Locksmithing
Need schlage deadlatch part replacement
Go to this link: http://www.schlage.com/en/home/products/products-hardware-accessories.html
Browse door hardware parts and decorative entry door accessories from Schlage.
Locksmith Hamburg NY 716 646 8383 24 Hour Locksmith In Hamburg NY
Aug 08, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage keypad lock does not unlock due to broken spring
Schlage locks have a lifetime warranty against mechanical defects. You can contact them here:
Warranty & Technical Information: 1.888.805.9837
Mar 18, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
The switch that unlocks my schlage FE595 door lock from the inside needs changed and I can't find a replacement.
Schlage's warranty policy covers the electronics for 1 year to the original purchaser. Last week I answered another question about buying the keypad assembly for a Schlage lock. Here's his experience:
"I had commented on their site about no spare parts being available and one of their reps contacted me and says they are going to replace the lock for me. This is a very generous gesture on their part and if it comes thru, will be a great deal for me. However, the problem still remains that there are no parts available for the other people that have this same problem. The locks have a lifetime warranty on the finish and mechanism but the electronics only have a 1 year guarantee...."
I suggest that you contact Schlage, but you will probably find that you can't buy the switch you need. Plead your case, ask to have it elevated, make a negative comment on their website like the other gent did.
Here's the contact information:
Go to Schlage.com Click on :"For your Home", then "Service & Support", and under that "Contact Us"
Feb 26, 2012 | Schlage FE595-CAM-ACC FE595CAM620ACC...
Schlage FE595 keypad replacement part
Your best bet is to contact Schlage directly. You can call during Midwest business hours (Mon.-Sat 7-7) at this number:
Warranty & Technical Information 1-888-805-9837.
For further information for the FE595 (installation & programming manuals and videos), go to this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx
The manuals are PDF files. If you cannot open them for viewing, you need to first download & install Adobe Reader, which you can get here:
http://get.adobe.com/reader/
Feb 21, 2012 | Schlage Electronic Lock FE595 Plymouth or...
I don't know the model number of the lock. It was installed in 1993.The latch broke. I got a new latch but cannot get it to work. Either it won't go or the handle slips. It does not have a key....
Start on this web page to identify your lock:
http://consumer.schlage.com/Products/Pages/category-landing.aspx?category=Electronic+Security
Then go to this page for links to the proper instruction and programming manuals and videos for your lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
If you're still having a problem or need parts, here is the contact information for Schlage Customer Service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Hope this helps!
Jun 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
My schlage keypad lock has worked fine for a year. Yesterday, I entered the code and the handle would move but nothing would engage to open the door. It was if I was using the wrong entry code. I...
This is the first place I urge you to look for information on your lock:
On this page you will find links to installation instructions and videos for the various models of Schlage locksets.
I f you are not able to resolve your problem from there, then I recommend that you contact their Customer Service (under the Service and Support link) also found on that page.
There's always a good chance that you can press them to cover repair parts or replacement of your lock, even if it is out of warranty.
May 13, 2011 | Schlage Locks & Locksmithing
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
The thumb part on the outside has come off, How do I put it back?
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Jan 01, 2011 | Schlage FE365-CAM-ACC Lifetime Polished...
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
119 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
