Question about Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime Traffic & Maps ($349.99 before $70.00 savings)
Nuvi cure rgn
Comes on, go to instructions, where to etc, then shuts off. will not re start untill powered off.
Screen is off one row. When I push the erase button 0 shows up etc. Can this be corrected?
Yes, recalibrate the screen. Here is the procedure:
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Jul 30, 2013 | Garmin nuvi 205 GPS Receiver
How to get free India maps for garmin nuvi 205W GPS?
You can download India maps from MapCenter (http://mapcenter.cgpsmapper.com/maplist.php?cnt=102&rgn=)
Jun 18, 2010 | Garmin nuvi 205 GPS Receiver
Nuvi 215 does not boot. As soon as the Garmin logo appears it reboots itself and continues in an indefinite loop
FIRST, be certain you have a fully charged battery.
Then try doing a master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to perform a master reset on your nuvi 200, 205, 465, 500, 600, 700, 705 or 1000 series device?
To perform a Master Reset
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Jan 17, 2010 | Garmin nuvi 215 GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
NEW GARMIN MISSING SOTWARE MODEL NUV1 200W
I did exactly the same thing!. This is how I fixed it.
Use Updater.exe NOT WebUpdate. Download the latest firmware for your unit (the rgn file), then connect your nuvi via usb. Turn it on and hold the power button left, at the same time drag and drop the rgn file onto the Updater,exe. It will start automatically and reload the firmware over the corrupt one.
Here are the files:-
http://e-trex.info/fw/nuvi/2x5w/fw_nuvi2x5W_ID0827_en_v460.rar
Enjoy
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
System software missing
Enjoy
Dec 20, 2008 | Garmin nuvi 200W GPS Receiver
My Garmin 205 shows "system software missing" after update. Tried to hold on the start button for a minute and tried to touch the lower right corner on screen, but its dead...
Hey!
I just got an answer from Garmin Support Germany and they sent me an file which fixed the problem. Just download http://e-trex.info/fw/nuvi/2x5/nuvi205_085101000280en.rar
It contains a "Updater.exe" and a file called "085100010270.rgn".
Follow the following steps and you should have your nüvi back.
Firstly connect your broken nüvi. Then drag and drop the 085100010270.rgn on the updater.exe. Choose USB as a connection and it should put an old firmware back on your device.
I hope I was able to help you!
Alex
Dec 03, 2008 | Garmin nuvi 205 GPS Receiver
Open the webupdater and just reinstall the software,click reinstall 0ac8987.jpg
Oct 19, 2008 | Garmin nuvi 205 GPS Receiver
Enjoy
Oct 19, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime Traffic & Maps ($349.99 before $70.00 savings) Logo
242 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
